Question about Samsung HL-R6168W 61" HDTV
I have a grey bar on 1 side of the screen. The shaded area goes from the bottom to the top and extends about 4 inches in width.
Hello, Can you clarify.
What do I need to resolve this problem.
I too have the same problem. I assume it was caused by me moving the unit.
Posted on Mar 17, 2010
    Problem Solver:
  • 16 Answers
If you can see video thru the shaded bar it is a light tunnel shifted in the optics --
Posted on Feb 06, 2010
Samsung un55d8000 shaded area bottom of screen
That is not a good sign. Since a TV screen utilizes what is called scanning lines and the data starts at the top zips side to side until it reaches the bottom; so fast you cannot observe that sequence; the same digital lines should be equal all the way from the top to the bottom. When any variation occurs (such as what you have mentioned) the lower light emitting diode rows are compromised. In a sense these lines are working at 1/2 capacity. This could be an issue with the controller and/or other devices on the circuit board. The company Samsung has a technical service department and a technician should be able to test out the problem described. If it is under warranty, have them replace it. It will only get worse in the future.
Dec 19, 2013 | Samsung UN55D8000 55" 3D LED 240Hz 1080p...
Without using legrange multipliers, determine the dimensions of a rectangular box,open at the top having a volume of 32ft^3 and requiring the least amount for its construction.
Given a "rectangular" box, the dimensions of side #1 will match the dimensions of side #3.
Similar for side #2 and side #4.
X = width of sides #1 and #3 of the box
Y = height of the box
Z = width of sides #2 and #4
Then, X times Y times Z is 32.
Area of side #1: X times Y
Area of side #3: X times Y
Area of side #2: Z times Y
Area of side #4: Z times Y
Area of bottom: X times Z
So, minimize: 2 * X * Y + 2 * Z * Y + X * Z
subject to: X > 0 and Y > 0 and Z > 0
and X < 33 and Y < 33 and Z < 33
Or, if you restrict X and Y and Z to be integer-valued, you can "brute-force" it,
i.e., try all combinations:
X Y Z MATERIAL_USED
1 1 32 98
1 2 16 84
1 4 8 80
1 8 4 84
1 16 2 98
1 32 1 129
2 1 16 68
2 2 8 56
2 4 4 56
2 8 2 68
2 16 1 98
4 1 8 56
4 2 4 48
4 4 2 56
4 8 1 84
8 1 4 56
8 2 2 56
8 4 1 80
16 1 2 68
16 2 1 84
32 1 1 98
So, '56' is the MINIMUM value:
2 2 8 56
8 2 2 56
2 4 4 56
4 1 8 56
8 1 4 56
4 4 2 56
Jun 04, 2011 | Acer Computers & Internet
Sharp 26"hdtv started with a 1/16" color bar that
If you mean the bar goes top to bottom, there are circuitboards that feed the info in small sections top to bottom. But usually one section will be one inch wide. It can also be the screen panel itself. Try a trusted tv shop
Nov 25, 2010 | Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
How do you make a buttonhole with a Bernina 830?
Hey, I have a Bernina 830 Record. If it's the same machine, set your stitch length at 0 then back it off about 1 to 2 turns. The middle button is your button hole. Got to one and it goes down the left side, #2 is the bottom cross bar, #3 goes backwards up to form the right side of the buttonhole and $4 is the tack across the top, #5 stitches it into place. I have my original manual if you have any other questions!
Donna/Portland OR
Apr 06, 2010 | Sewing Machines
Model is Satellite P105 S6024, serial # 86019106W About one inch from right-hand side of screen, a 'white line' (in appearance) has appeared. It is about one inch in width, and goes from top to bottom of...
When you get vertical lines from the top of the screen to the bottom of the screen, it means you have bad LCD panel, you need the new one. It will get worst with more lines as time goes by.
Mar 04, 2010 | Toshiba Satellite P105-S6024 Notebook
Jenn-Air JMV9169B top cabinet stencil
I would suggest contacting Jenn-Air / Maytag / Whirlpool customer service on this one.
Nov 01, 2008 | Jenn-Air JMV9169B Convection/Microwave...
Shady bar
no auto alignment i think it's the lamp engine. or grey scale aligment
Dec 22, 2007 | Samsung HCN4226W 42" Rear Projection...
Shaded area on tv
CHECK THE OPTICAL ENGINE. THEN AGAIN THE LG BRANDS BELONG TO GARBAGE TIP
Aug 27, 2007 | LG RU-52SZ51D 52" Rear Projection...
I have have this TV for almost 3 yrs..now have a shaded area on the left side
The dark side of the screen causes of the lamp alignment or prism glass alignment. This is critical you have to consult your LG technician to do this. But if you have any background o repair consult the service manual. Please careful not to touch the prism quarts so that you maintained the clarity of picture and brightness on the screen.
Samsung HL-R6168W 61" HDTV Logo
214 people viewed this question
Jerry Greenberg
Jerry Greenberg
