Question about HP Photosmart C7180 All-In-One InkJet Printer
I have an ink system failure. ERROR CODE: Oxc18a0206
I have an ink system failure. I live in the Mojave Desert and haven't used my printer in a couple of months. I now get an ERROR: Oxc18a0206 Ink system Failure. Refer to printer documentation. I replaced the ink cartriges but to no avail. Do you think some other part of the ink system may have dried shut, inside where the ink goes. I am starting a new home business and NEED my All-In-One Printer, PLEASE HELP !!
Larry
Click on this link below and follow the steps on that page to fix your HP Photosmart C7180 ink system failure:
http://www.fixya.com/support/t3655088-error_oxc18a0206
Posted on Feb 06, 2010
HP Photosmart C5180 printer error message Oxc18a0206
Use your machines own programme to clean the ink heads
Feb 20, 2016 | HP PhotoSmart Office Equipment & Supplies
How do I fix an hp printer with Oxc18A0206 error message
Try this
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
May also be a failed printer or clogged ink from lack of use or bad ink.
Oct 17, 2014 | HP Photosmart D7360 Printer
How do I fix "ink system failure oxc18a0206" message on my HP Photosmart C7280 all-in-one?
Hopefully, this link will take you to the proper troubleshooting page.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03081973&lc=en&product=3204785&tmp_track_link=ot_search#N213
You'll click on the third plus sign on the page (+) because your message DOES include the words "ink system failure."
From there, you'll choose, by looking at the pictures, whether your printer has a removable print head.
You'll click on the appropriate answer -- yes it does, or no it doesn't,
Then, you'll identify which print cartridges your system uses, and THAT will take you to the proper troubleshooting steps for your printer's specific configuration.
The fix may be something you've already tried -- turning off the printer and unplugging it (but did you unplug it from BOTH the unit AND the wall, and then did you wait at least 15 seconds?), or the fix may be to service the printer.
Good luck! :)
Aug 07, 2014 | HP Photosmart C7280 All-in-One Printer
How to fix Ink System Failure Oxc18a0206 error message?
Hi John,
Please do check this link which will give you the detailed steps about the HP Cartridge Printer issue that you have
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&cc=us&lc=en&dlc=en&product=439491&tmp_track_link=ot_search
Jul 13, 2014 | HP for D7355 D7360 D7460 D7355 12 Pack 02...
Hp photosmart c6150 all in one error oxc18a0206
hey, with this document you will be able to fx the printer if you ever got a message like ink system failure 0x...
on hp printers
http://rapidshare.com/#!download'253l34'140957209'Assert__Ink_System_Failure_Actions_for_PhotoSmart_Six_Ink_Products.doc'258
Mar 03, 2011 | HP Office Equipment & Supplies
Hello I just replaced all the inks and now I keep getting the error oxc18a0206
This error code indicates a 'Ink System Failure" this is caused by air in the ink feed tubes. If you allow the cartridges to fully run out or you use pooly filled refill cartridges it can allow air to be sucked up into the feed tubes. To clear the error you will need to do a purge routine. We hae a step by sep guide posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ It should take you about 10 minutes to finish and then you will be as good as new.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 18, 2010 | HP Photosmart C7180 All-In-One InkJet...
Error code Oxc18a0206 ink system failure
I had this same exact problem. Try doing:
I had to go through multiple tries of the solution above. I turned it back on, it shut off and I turned it back on again. I tried to print something and sure enough, it did a maintenance cycle and it works again.
This did not work the first time but after 3-4 times of doing both, TA DAH, it went through a lengthy maintenance cycle and then started working. Persistence paid off
Jan 22, 2009 | HP Photosmart 3310 Printer
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
I had this same problem but with a different error code. Try doing:
After I did this my printer reconfigured like it used to do and it was like it was new again.... well new plus a headache a managed to get while reading all these little posts. I hope this helps!
If not try going to this website:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers
Mar 02, 2008 | HP Photosmart 3210 Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
516 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
