Question about Keurig Single Serve Ultra Brewer
Looking for replacement check valve for our coffee maker
    Champion:
  • 213 Answers
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Posted on Apr 18, 2010
Tip
How to repair a DCC-1200 Cuisinart Coffee Maker
Problem #1 - DCC-1200 makes steam - not coffee. Reason: the check valve is plugged - water will not flow.<br /><br />Solution #1 - Remove the check valve located inside one of the 2 silicon tubing hoses inside the coffee maker...and clean the valve. You must remove the bottom of the coffee maker (problem #3). Note: the check valve is not plugged due to hard water minerals. It plugs up from coffee grounds and coffee residue. Thus...use the charcoal filter, and clean with 50% white vinegar on a regular basis.<br /><br />Problem #2 - Removing the check valve located inside the tubing. You must cut it out and thereby destroy the tubing. Replacement is required.<br /><br />Solution #2 - purchase one foot of 3/8" SILICON tubing over the Internet from Rebel Brewer at <a href="http://www.rebelbrewer.com">www.rebelbrewer.com</a>. Silicon is required to handle the high temperature.<br /><br />Problem #3 - removing the bottom plate. It is secured with four "custom" torex screws that cannot be removed with a normal torex tool. (not designed to be easily removed). <br /><br />Solution #3 - I used a 1/4" drill bit and drilled off the heads of the screws. The bottom is easily removed. I was able to snap it back into place. You can use some silicon caulk at the 4 corners for a more secure fitting.<br /><br />Good Luck - not too difficult<br /><br />Camanokid
on Apr 15, 2011 | Cuisinart DCC-1200 Coffee Maker
I'm looking for a replacement coffee pot
mcdevito75 here, Check with any store in your area that sells coffee makers for replacement pot, Walmart, etc.
Jun 28, 2010 | Kenmore KBC12 Coffee Maker
Dripping water from frother during coffee making, leaks water under unit - mixed with darker colored residue
Check the small chamber behind the white plastic valve, that might be filled with coffee grounds and water. For the leak while making coffee the steam valve needs to be rebuilt or replaced.
Nov 28, 2009 | Saeco Incanto Sirius Fully Automatic...
Coffee won't come out of coffee maker
Sounds like the dispensing lever is broken. I had the same problem. I am still looking for a part. If the coffee is brewed and in the upper tank then the lever is not pushing on the valve. I glued mine several times but it keeps breaking.
Jul 09, 2009 | Hamilton Beach BrewStation Deluxe 47474...
Krups XP2070 coffee machine - new - espresso side - water goes straight into the drip tray & not thru the filter. I have the exact same problem-that's why I'm on here looking for a solution!
You either have a blocked filter or defective valves. Try the unit without the filter to see if you get liquid out of the group. Most likely you have defective pressure valves (pair) which are not too expensiv to replace.
May 30, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Looking for replacement parts
Starbucks no longer offers replacement parts nor any form of support for the Barista (Solo or Grande) coffee makers...eBay is your best bet!
Apr 02, 2009 | Coffee Makers & Espresso Machines
Need a new check valve for a Keurig B70 coffee maker
http://www.igotsweetdeals.com or http://igotsweetdeals.ecrater.com/
We have most parts for Keurig b30, b40, b50, b60, b66, b70, and b77.
If your parts not listed just send us an email and let us know what part you need. In most cases we can have the part pulled and shipped the same day!
Our parts are used and the prices are exceptionally fair. Ask about our scratch and dent parts to save more money!
If you have any questions about your Keurig or your having a problem just give us a call and we may be able to help you.
Feb 19, 2009 | Keurig B100 Coffee Maker
Cocoa latte hot drink maker
replacement parts for valve, lid, and bowl can be found here
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3169&secid=53&linkon=subsection&linkid=118
part no. description Price
U27-2 Lid, White. CA series
$3.50
U18-182 Blending Jar with Built-In Stir Paddle
$12.00
U17-104 Dispensing Valve, Beige. Interchangeable with all Cocoa Latte Models
$5.00
Jan 23, 2009 | Back to Basics CM300 Coffee Maker
Looking for a Carafe replacement for my GE coffee maker
I've replaced my coffee pot from my local Ace Hardware!
I'd call first!
Good Luck!
Jan 18, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
495 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
