Question about Sharp LC-52D43U 52 in. LCD HDTV
52" SHARP LCD getting a snowy picture after 5 to 10 minutes
My 52" SHARP LCD TV gets a snowy image after it is on for around 10 minutes. If I switch the input from TV to DVD then to computer I get the same effect so I think it is not the cable. I am thinking it is a cold solder joint on a part inside the TV but witch one? When I first got the TV the snow would show up but then it went away. For 4 months the TV was fine but now the snow is back. When I tap the back a little the snow will flicker. Any ideas what part this might be? I am also looking for a service manual so I can fix the problem myself.
  • Jacko Feb 21, 2008
    These are the pictures of the snow.
  • Jacko Oct 18, 2008
    Sharp will not fix this problem because it was bought at Costco and I am not the original owner. Luck I am a bit of a tech and I have tracked the problem down. I put a fan on the inverter board and the problem went away. I will open the protective
    Normal
    0
    shield soon and track down the part that is over
    heating then glue on a heat sink using thermal grease. If there is anyone out
    there with advise it would be much appreciated. Thanks for any support!
    New Friend:
  • 3 Answers
I HAVE THE SOLUTION!!!! My 52" was doing the same thing. It would work and then picture will go to snow and no inputs worked, the remote didn't even work! I would have to power everything down (Reciever, PS3, etc.) then it would work but no telling how long. Even touching the TV where the buttons are made it go to snow!! THIS IS WHAT YOU DO. Take the back cover off. Where the side buttons are, there is a board in there and it is touching the metal frame. Take something like a credit card and cut it enough so that it will not be sticking out, get some electrical tape and anchor the card to the metal frame so it will not fall out of place. You're basically protecting the board from touching the frame!! Put the back side back on and screw in place and your all set. My TV has been working perfectly ever since.
Posted on Jun 24, 2013
    Sniper:
  • 53 Answers
Main Board problem. Call sharp or local sharp authorized service center to fix this problem.
Posted on Mar 15, 2008
  • Mark Hudson Jun 24, 2013
  • 103 Answers
These sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.They have fixed these ynits out of warranty with a smile.This is a issue with defective parts not connections
Posted on Mar 05, 2008
Snowey on scrreen
I've been repairing TV's for over 15 years and I would say either a bad Tcon's or main board issue. Theirs no need to replace capacitors these days, you can get the main board from $40-60.
Have you tried using different devices on the unit? If your getting a snowy picture on a satellite receiver, check with your provider for troubleshooting guide their unit. Or let me know the provider and I can lead in you right direction.
Thanks,
Jason
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Jun 09, 2016 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Hook up my dvd/vcr player
You probably need to change the input on your tv to match the input you are plugged into. On your remote should have a button that says source or input. With you recorder on switch through until the image comes up.
Jan 21, 2015 | Televison & Video
Snowy picture
Can you say it does it on all inputs including DVD etc?
Snow in the picture to me does not indicate a T-conn board.
Jun 15, 2012 | Samsung LN-S4051D 40 in. LCD Television
We have a new 46" Sharp Aquos with a "snowy"
sounds like you have a cable connection problem make sure your tv is set to dtv signal in the menu screen. when you scan the channels should be displayed as 12.1 or 8.2 not just a single number if the digital channels are programmed correctly then change the cable coming into the tv from antenna making sure that it isnot crossing any power wires good luck and hope that i helped
Nov 07, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Poor picture quality on cable input
Try swapping some cables around, like the skart lead from the dvd(if scart) for the cable one, if the picture problem swaps with the lead then thats the problem. If it doesn't try settings on the cable and tv, if the cable is sending nvbs signals and the tv is set to pal then this can also occur.
Jun 30, 2009 | Dell W2306C 23 in. HD-Ready LCD Television
Sharp LC-52D43U 52 in. LCD HDTV Logo
828 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
