Question about LG LDF8812 Stainless Steel Built-in Dishwasher
Have a broken door spring, how to change it on my LG dishwasher
  • 155 Answers
It may not be the spring it could be the cord it connects to you can check this by removing left or right hand side panels which will expose the hinge.good luck
Posted on Feb 06, 2010
docjohn174
  • 943 Answers
SOURCE: Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Posted on Oct 06, 2008
SOURCE: broken door spring on kitchenaid dishwasher
uitg
Posted on May 30, 2008
  • 258 Answers
SOURCE: Dishwasher broken door spring
see http://www.howtofixanything.co.uk/howto-dishswasherchangespringtricitybendex.html
Posted on Jan 11, 2009
  • 3 Answers
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Posted on Feb 15, 2009
rickead1
  • 1998 Answers
SOURCE: Broken door spring on Kitchenaid dishwasher
you have to pull the unit totally out so you can access both sides of the machine you can order the parts from either marcone or allbrands applaince they mail the parts directly to you when you have the unit out you will be able to see its an easy fix of just replacing springs and cord if im remebering correctly theres only two 1/4 screws to loosen one on each side you will be replacing the glide rollers also in the kit they send you with the cord are the glide rollers
Posted on May 01, 2010
Suspect door spring/assembly broken. How do I repair same?
If it's like my whirlpool, pull it out. Spring should be obvious. I doubt the hinge portion is broken. Spring may be. While it's out and springs tend to break, I would replace both. Several online appliance parts stores can help you with springs, my diagnostics and Hinge issue. They have been helpful to me.
Apr 02, 2015 | LG 24 in. LDF 7811 Stainless Steel...
The dishwasher door spring has snapped, the door is heavy, can I fix it myself?
Yes, you can repair the unit yourself. It will require removing the dishwasher out of the cabinetry to get to the spring cable. The spring is not the problem but the connector between the door hinge and the spring is broken.
The part you need is 4933DD3001B. You will need 2 of them.
Hope this helps.
Oct 29, 2011 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810st dishwasher door spring seems to be broken so door falls open. Can this be fixed easily?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Aug 10, 2011 | LG LDF6810ST Stainless Steel Built-in...
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Feb 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Nov 28, 2009 | LG Dishwashers
I have a kenmore dishwasher that is 18 years old not sure of the model my wife tells me that the door seems heavier than before I am thinking a spring has let go if so how do you change the spring or fix...
Most likely the spring or springs that help the door up are broken. Usually, if you remove the lower front panel (usually 2 screws hold it on) you can access the springs. If they are broken, try your local appliance repair store for new ones. If they are that old, they may be rusted- be careful!
Dec 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
WHEN OPENING THE DISHWASHER DOOR, IT DROPS QUICKLY.
Actually I found out that for a LG dishwasher it is as likely to be the cable/cord attached to the spring and door. This a very odd setup in that this cable is made of nylon cord, and not any thicker than a round shoelace! It clearly should be metal cable, and it's not that hard to replace the nylon stuff with steel. Anyway, it is worth it to pull the unit out and open the side panel to see if in facts it's a broken cord or spring first before ordering any parts.
Dec 04, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Bosch dishwasher
You have to remove the entire dishwasher from under the counter. Then locate the broken cable. There is a panel you need to remove to access it. It attaches to a spring which goes to the underside of the dishwasher. Not an easy repair. Need alot of patience for this but it is doable.
Apr 08, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
747 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
