Question about Jensen's VM9312 Car DVD Player
My screen went black but still works model vm9311ts
Vm9311ts screen displays "stop"
Did you ever found the solution for the vm9311ts? I have the exact same problem
Jun 21, 2012 | Audiovox VM9311TS
Looking for replacement remote for jensen car sterio w/ cd.dvd/lcd 7in touch screen monitor. VM9311TS
You're not going to believe how easy this is...
visit remotes.com and enter your model number.... cool!
May 31, 2010 | Car Audio & Video
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
Jul 21, 2009 | Computers & Internet
Hp pavillion zx 5000 screen black
GO ON LINE AND TYPE THE MFG NAME, MAKE, MODEL, SCREEN WENT BLACK.
ENTER
ROD
May 12, 2009 | HP Pavilion dv6000z Notebook
Where is my multimedia device for my VM9311ts?
hey bud got the same model in dash. it won't work unless u have the brain (multimedia unit). nothing would work no radio or nothing. pull it out and look for a black cable besides ur antenna follow that and u will find the device
Jan 26, 2009 | Audiovox VM9311TS
Is a media link box and media module the same for jensen vm9311ts
they are not the same. the media link will work for that model.
Jan 17, 2009 | Jensen's VM9312 Car DVD Player
Grounding the bypass parking switch for vm9311ts
This is a newer product.You can't just ground that orange cable like the older modles.I posted a solution somewhere here on the forum.
Mar 10, 2008 | Audiovox VM9311TS
How do i bypass the parking brake switch in order for my video to play
hook the pink wire to a toggle switch and ground the switch to the chassis. when the unlawfull screen comes on then turn the switch on for a few seconds then back off for a few seconds then back on and the screen should go away. I done this with mine and it works. unfortunately you have to do this every time.
Feb 23, 2008 | Audiovox VM9311TS
CAN U HELP ME?
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
Dec 27, 2007 | Audiovox VM9311TS
Dvd player on Jenson VM9311TS
well if u haven't fixed it yet this is what u do. now that u have the toggle switch and that blue screen is gone ,now u put that code in . u put a dvd in when it starts u press stop twice on the remote then press1264 . as soon as u put in that last number a menu will appear on the screen that says
this what u should have it at if not then change it to this
REGION:1
BRAKE OVERRIDE: ON
MACROVISION: OFF
Dec 23, 2007 | Jensen VM9510 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
70 people viewed this question
Top Jensen's Car Audio & Video Experts
Tre Elkins
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
