Question about Belkin ExpressBus (F5U021) 4-Port USB Hub
How may i connect my macbook and my mac mini and an external hard disk and have access in both computers to each other as the external hard drive too using hub F5U021?
2 Suggested Answers
suxia
  • 142 Answers
SOURCE: Disappearing files from Hard Drives
find if you portable deviceshas any SAFETY REMOVE function, if you using hot plyg and unplyg function without firs safety remove it causes this action, same is in flash drives. because writting process is not finished when unplug and last transaction had not been writen and file allocation table has wrong data in it.
Posted on Aug 18, 2009
How do i eject two disks in disk drive
You could try something that sometimes works on MacBooks - leave the drive plugged in and restart the computer. As it boots up, hold the eject key down.
Jul 23, 2014 | Apple External Usb Superdrive For Macbook...
How to initialize disk
Do you want to initialize the hard drive on your Mac? Or an External Hard Drive?
Assuming External Hard Drive:
  1. Go To Applications.
  2. Open Utilities Folder.
  3. Open Disk Utility (You Should Already Have External Drive Attached To Computer).
  4. On left panel select the top name of the external hard drive.
  5. On the upper tabs on the right side of the panel select Erase.
  6. ***Note this will delete any content on the external hard drive
  7. Under Format - Choose Mac OS Extended (Journaled)
  8. In Box Below Name The External Hard Drive whatever name you want it to be.
  9. On bottom right select erase.
The External Drive will be Mac Compatible.
Let me know if you were trying to accomplish something else.
Jan 04, 2014 | Apple MacBook Air
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Apr 21, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
I was able to use my Hitachi xl 1000 external hard drive on my computer and I wanted to be able to use it for my Macbook Pro as well but as soon as I used it for Time Machine Backup I wasn't able to use it...
If the MAC formats the external hard drive then the desktop cannot see any files on the hard disk even though it detects the external hard drive.
If you format the external hard drive using the Desktop computer and format it in FAT32 then the MAC can read and write to this hard drive and the desktop PC can also read and write to the external hard drive.
MAC computers can read and write on PC formatted disks but not the other way around.
Jun 29, 2010 | Computers & Internet
Hi, my WD hard drive is connected to my macbook, but can't access
check under the system profiler which can be found in the applications folder and then in the utilities folder. See if under usb whether the drive is showing under there. If it is, open up disk utility and use the verify disk to see if there is a problem with the drive, if there is use the repair disk to repair it.
Other things to check try a different usb port on the macbook or a different usb cable.
Hope this helps
Oct 21, 2009 | Western Digital 250GB MyBook External USB...
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
Maxtor OneTouch III Mini not appearing on MacBook Pro
Hi Lois,
If your Maxtor appears in Disk Utility but the disk volume is not displayed, it's possible that the partition on the disk has been deleted for some reason. If that's the case, you will have to use a disk partitioning utility to create a new partition and then format the hard drive.
Best wishes,
Graemevm
Apr 28, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Configuring FreeAgent for Mac OS
Lesson No. 1 - Never buy hardware or software from a store at which sales staff think the best way to answer your Mac questions is to convince you to buy a PC.  Lesson No. 2 - Reformat the drive using the Mac Disk Utility included with your MacBook after consulting with a store at which the sales staff know there is more to the computer world than PCs.  If you only intend to use the drive on your Mac, choose the option Mac Extended Journaled when rewriting the drive. There is also an formatting option to use the drive on both PC's and Macs. But I'm not going there.
May 21, 2008 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Belkin ExpressBus (F5U021) 4-Port USB Hub Logo
82 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
