Question about HP Photosmart 7450 InkJet Printer
HP Photosmart 7450 Printer
My HP Photosmart 7450 printer suddendly stopped feeding paper. A close inspection revealed that the long shaft the paper drive rollers were mounted on did not turn when it was attempting to feed paper. The motor would run and the large black gear would turn, but the shaft would not.
While inspecting the unit I noted a rattle, turned it upside down on a clean workbench, and a small 1/16" diameter x 5/16" long stainless steel pin fell out.
Great, that's probably the problem. BUT,,, I can't get the top cover off.
Three screws holding down three of the corners are plainly evident, but the fourth corner, the left front, is secured by something else, probably a plastic clip. I have looked inside with an inspection mirror and cannot locate the hold down element. Tried all along the joints with a small screwdriver trying to release a hidden tab. No luck.
Hope it's not one of those once you snap it together, you must destroy it to get it apart, locking tabs some manufacturers use to tamper proof their products.
Any insights.
HP was their usual, helpful selves. After about an hour of explaining my problem several times they simply said "No user servicable items inside".
A link to a service manual would be helpful also.
The unit is rarely used, so this is not a worn out parts issue.
I just need to fix it. Any help would be sincerely appreciated. ---- Thanks
  • 1 more comment
  • 4Angyls Mar 16, 2008
    My printer has stopped taking in the photo paper I have always used. For some reason it takes in regular paper. I love my printer for the quality photos I get but can't get it to take in my paper. Someone please help! I am pretty illiterate in the world of fixing any type of electronics so I need big help. I am an amateur photographer and need my printer.
  • KDPhoto Mar 22, 2008
    My HP Photosmart 7450 won't take any photopaper anymore. It jams or won't even take it in 100% of the time. Although it will print on plain paper most of the time, I need to print photos!!! I'm ready to toss this POS, and forget about ever getting another HP, as this problem is something I've had in other models as well. What's up HP???? Fix this darn problem already!!!
  • Anonymous Feb 11, 2009
    I have no display on the front panel but I have power
I had the same problem with my HP photosmart 7450. It started with frequent paper jams, to the point where it happened everytime it pulled the paper in to print. I had the rattle also, turned it upside down and the pin fell out, just like yours. I'll bet it's happening to many other 7450's. Anyway, I was able to repair it myself.
The pin attaches to a small black plastic gear, about 1/2 in. in diameter, in the paper feed roller, (on the right side, and not visable from the front). I had to remove the misc. covers, several screws attaching different things, includind the sliding ink absorber on the right side, (that was fun) to where I could see the loose gear. This was no easy task. I'm an auto mechanic, so I enjoy a challenge. However, as much as I like the printer, I was ready to toss it in the dumpster if I couldn't figure it out. First you'll need a small "torx" screwdriver or two, as well as some other basic tools. If you're patient, good with your hands and have a good sense of how things work, you can probably repair it yourself also. Let me know if you're successful.
Good luck!.....Ron J........ street@inreach.com
Posted on Mar 17, 2008
  • fixes stuff Mar 17, 2008
    PS....
    To remove the left front cover(s):...There's a narrow (1/2 in. wide) dark gray plastic strip that snaps in under the display window. Remove that, starting from the left , and you'll see 2 screws in front, thay attach the digital display. Remove those, disconnect and remove the display unit and both covers lift right off...Ron
Here are my findings of the way in to my HP7450. The start (up to removing the small grey (I found black) strip follows Ron J's instructions, and I am most grateful to him, because that gave me the start I needed.. But when I got the strip off, I found a single screw, and removing it did not give final access to the innards Read on.....
It may make life more convenient to unclip the two hinges and remove the top grey cover. Slide firmly downwards and forwards.
Unscrew the first three Torxx screws (size #10). Two are at the rear of the case, and the third is at the bottom of the well where the spare ink cartridge goes.
All of the subsequent operations refer to the section of the printer to the left of the top door.
Release the black plastic plate (roughly 10 ´ 120mm) that looks like trim in the middle of the left-hand section. Slide (maybe lever gently) from the left: it is fixed by a lipped holder on the left and a spring clip on the right, and it is this latter clip you are trying to push against.
With the black trim off, a small Torxx screw is exposed, which is smaller than the three removed so far. Undo it.
The next item to be removed is the grey cover. It can come off with the black left-hand side panel still attached. It is held by two small spring catches. The locating holes for these are found in the black section normally covered by the upper door. One of the clip holes is below the grey panel at the top, and the other is towards the bottom of the panel: both holes are, of course, on the vertical faces of the black frame.
Both clips must be pressed in at the same time, and the grey panel will then slide forward and can be removed. The upper printed circuit board (PCB) and electronics are now exposed.
The PCB can be partially freed by lifting the two black clips at the top front. Gently ease the PCB forward. (CAUTION: be careful not to damage any wiring or electronics, and remember that the components may be destroyed by inadvertent static charges). When this operation is completed, a fourth Torxx #10 screw can now be found in a recess towards the right of this section. Remove it.
The whole of the upper box assembly is now held by just one further plastic clip exposed by moving the PCB. Release the clip and lift the assembly a SMALL distance. There is a multiway strip cable connecting the electronics in the top with the electronics in the bottom. GENTLY pull the connector at the end of the cale out of the socket on the PCB in the lower section, and remember which way round it was for reassembly.
Now you have the various bits of the HP 7450 separated for the next stages of work!
I hope that this helps someone, but Ron J deserves the credit.
Richard W
Posted on Sep 13, 2008
I have the exact same problem, and cannot find a way to get the front left of the cover loose.
Posted on Mar 06, 2008
    Genius:
  • 3,587 Answers
I put paper in the printer, but it will not recognize that there is actually paper in the Machine.
The paper feed sensor is malfunctioning.. I would suggest cleaning if that doesn ot work..and it still does not feed you will need a new sensor.. Rate me by advice only Thanks
May 20, 2009 | HP Photosmart 7450 InkJet Printer
Prints "fast draft" only
hi to all ... my printer did not work good when I give it order to print the first paper let it with out pint but it print after that a bout 5 sheet than stop .notis I order one copy.....what should I do
Dec 18, 2008 | HP Photosmart 7450 InkJet Printer
HP Photosmart 7450 immediately either jams or light turns red.
This link will give you information on clearing random jams that can happen with your model. Just click both links and follow the instructions listed there.
Also, this link will give you information and steps to take regarding the lights on your product.
Hope this helps. Please remember to rate this information.
Thanks
Nov 26, 2008 | HP Photosmart 7450 InkJet Printer
My photosmart printer is saying out of paper, but the paper tray is full. Printer will not grab the paper
a detailed trobleshooting procedure for the error is given in this link...
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&docname=c01036504
Nov 22, 2008 | HP Photosmart 7450 InkJet Printer
Reinstalling
XP driver here: ftp://ftp.hp.com/pub/softlib/software3/COL8086/ps-22672-1/hp_72_enu_nonet.exe
[ Vista support not yet certified for Photosmart 7450, and uses standard printer driver]
Sep 28, 2008 | HP Photosmart 7450 InkJet Printer
HP Photosmart 7450
Most printers have a photosensor on the head assembly and the assembly (as it moves back and forth) rides on a strip of plastic that is dark with clear spots. That is how the cpu in the printer knows where (left to right) the head asm is located. So, If that strip is broken, or dirty or if the sensor is dirty this can happen. The sensor could also be defective. Try using some canned air to GENTLY blow away any paper residue in that area and then reset the power to the printer. If that doesn't help, then the printer needs serviced.
Hope that helps...
Geno
Apr 04, 2008 | HP Photosmart 7450 InkJet Printer
HP Photosmart 7450 stuck cartridge
not a solution, my paper feeds past the point where printer5.gif would normally begin. Then flashing light changes from green to red and print operation stops. Printer cartridge1.gif appears to be stuck in far right area of cartridge track.
Replaced drivers as above and still have the same problem.
Mine started after I had replaced the color cartridge. Mailed the old one to HP already so can't put in old cartridge.
If I unplug printer from computer, I get same results. Does the driver software install in the printer?
Geo
Mar 28, 2008 | HP Photosmart 7450 InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
HP Photosmart 7450 InkJet Printer Logo
878 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
