Question about Culligan Sediment Water Filter Heavy Duty
Just had a culligan hf-360 installed. Sadly,
Just had a culligan hf-360 installed. Sadly, the first one we purchased had a manufactured defect. Second one (installed), seemed fine but there is water accumulating in the top rim - looks like it's coming from the top swivel part (on the left side, the ''off'' side) which we tightened a bit. that seemed to help but it's still leaking. Anything we can do? Otherwise, it's working properly.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
It is leaking from the pressure relief button. Call them back and have them replace this one also.
RJ
Posted on May 16, 2011
Hf-360 leaking at cutoff valve
Hi
Going to the manual...it says if you have a leak like you are describing then you need to call tech support. this filter has a 5 year warranty. call 1-800-721-9243.For parts you can call 1-888-777-7962. Check out your manual here at http://www.culligan-store.com/pdfs/HF-360A_Rev_A-Manual.pdf Good luckne10810a
Feb 19, 2015 | Culligan HF-360 Whole House Water Filter...
Culligan water filter is leaking
Turn off water
Remove filter and seal ring.
Look at mating surfaces.
Usually the cast metal has eroded away.
If it is the sealing ring , replace it. If it is the casting , replace the whole thing. Other brands may be an option.
Jun 24, 2014 | Culligan HF-365 Whole House Water Filter...
Tahoe "ignition noise" hf
You need to ground it more so u don't get static that's all or find a better ground
Mar 20, 2013 | 2005 Chevrolet Tahoe
Culligan AC-30 osmosis water system housing leak
Depending on which type of plastic you have, it should say on it somewhere and it should look like a triangle and it will tell u pvc or nilon or abc. Then go get that type of glue and seal it with the correct glue. You could also use a food grade silicone, but remember to rough it up with some sand paper.
Feb 27, 2013 | Culligan Under Sink Water Filter
I need to purchase a re install disc for a high grade notebook
Usually if you go online to the manufacturers web site, they will have a downloadable version of the software and you can probably purchase it too. If having problems with the site, just call the manufacturers Customer Service Number and they can get you the software. You might be able to source it on Ebay also. Good Luck
Apr 17, 2012 | Cars & Trucks
Have an under sink Culligan RO system with 4 potential filters but it only uses 3 (was so installed by Culligan). Filters are labeled - reading left to right Sediment SED10 ...
Pre-filter and carbon block filter are changed annually. The membrane is only changed every 3-7 years depending on water quality coming in, TDS and usage. Fourth filter is an in-line carbon filter that goes on the line up to the RO faucet.
RJH2O
Aug 12, 2011 | Culligan Compatible RO Prefilter AC30AC15...
Can i get a 1/4 inch quilters foot for this machine and how much is it how can i get a manual for this machine, is it the same manual as for a hf 106
If you are unable to purchase through your sewing machine dealer in your area, check the manufacturer website...if that doesn't work, check eBay or Etsy auctions.
Jul 18, 2011 | Janome HF-107
Got xbox 360 elite, and want to live wireless do i need to buy an adapter for £60
Sadly yes, 360's do not come with Wireless capability out of the box. You will need to purchase the adapter
Dec 26, 2009 | Microsoft Xbox 360 Elite Console
I have a culligan water conditioner, are there filters inside unit? Im by passing the unit now. When water goes through system, water pressure drops.
yep got to replace the filters if any in line or your softners need to be relined if you cant see your filters in a plastic clear houseing then your sadly gonna have to call culligan water to come reline your tanks
Mar 28, 2009 | Plumbing
Death of X box console purchased 30.1.08
Carollesly, you can send the xbox away and get a brand new Xbox 360 console in exchange. All you have to do is pay for the postage. Contact the following numbers and they should be able to give you all the help you need!
Here are the Telephone details,
0800 587 1102
or +44 20 7365 9792 from a mobile phone
Hearing Impaired (TTY device):
0800 587 1103
If this is of no help all i can recommend to you is to go onto 'google' and type this in "Xbox 360 contact". Then it will come up first result 'Contact us' then click on that.
May i also add a bit of helpful advice to either you or your son, about once a month just clean the console with the hoover to get rid of dust build up and to have the console somewhere where it isn't hot as that can cause the 'Red ring of death' which your sons console has experienced.
Best of luck,
Ben
Feb 01, 2009 | Microsoft Xbox 360 Console
Culligan Sediment Water Filter Heavy Duty Logo
339 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Bill Boyd
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
