Question about Canon MX300 Office All-In-One Printer
I am having that same problom with the paper feed
The paper gets wrinkled to the right side its a brand new printer i shouldent do that but i guess its a waste of 100 dollar
  • Anonymous May 25, 2008
    paper does not feed, it will print like it thinks it has paper but will not pull the paper into the printer and print on nothing.?
I disconnected lifted upside down and gave a skake it really works and prints just fine!
Posted on May 11, 2008
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
The paper keeps getting jammed. The paper slides down the right side of the feed first and wrinkles up. I have tried all the trouble shooting listed in the manual and nothing helps. Help?? I can not print.
turn the printer off and on.. lift it shake it and drop it from 2 inches height.
if you have already done the rest this should work or else printer's bad.
Dec 14, 2009 | Dell A960 All-In-One InkJet Printer
Printer is destroying my papers
The problem sounds like it is the FUSER. It is notorious for wrinkling paper and causing black marks. Try replacing that, and you should be fine. It's NOT your paper... just try replacing the Fuser.
Sep 15, 2009 | Office Equipment & Supplies
Envelopes are getting wrinkled when run through the Brother DCP 9040CN. How can I prevent them?
Unfortunately when feeding envelopes it is quite common for them to wrinkle a little simply because of the way envelopes are folded. The paper is thicker in certain areas because of the folded paper and the glue that holds the envelope together. You could try different brands of envelopes some don't wrinkle as bad as others but in my 37 plus years of working on copiers and printers I have never seen any envelopes that won't wrinkle a little, you may just have to live with it.
Aug 19, 2009 | Office Equipment & Supplies
Paper wont feed propaly
It sounds like the motor on the left side went out. If it's a brand new printer your best bet would probably be exchange it at the store or see if the manufaturer has a warrenty. If it's an older printer I probably wouldn't try to get it repaired, printers are getting cheaper these days and it probably wouldn't be much more to get a new one.
May 26, 2009 | Canon PIXMA MP520 InkJet Printer
We are suddenly experiencing 2 problems. First,
The fuser needs to be replaced, it is causing your smears and the wrinkling/jamming problem.
Apr 28, 2009 | Lexmark T430 Laser Printer
Paper gets crumpled and wrinkled and won't feed.
is printer new i would take it back if u can if not go download ther latest driver ok may fix it up best u can do try feeding paper throw it fe w times train it
Oct 09, 2008 | Lexmark X2600 InkJet Printer
Brand new Lexmark X4270 All-in-one, won't copy, fax, or print
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If this not work i guess your printer is defective get it replaced>>>
Mar 17, 2008 | Lexmark X4270 All-In-One InkJet Printer
Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Feb 03, 2008 | Canon MX300 Office All-In-One Printer
Canon MX300 Office All-In-One Printer Logo
64 people viewed this question
old marine
old marine
