Question about Frigidaire Washing Machines
Brown & black spots on some of the clothes coming out of washer.
I have a 10 yr-old Frigidaire Gallery FWT647GHS0. Clothes coming out of washer have brown spots, some black greasy spots, and some little black lines. But not on all the clothes . . .just some of them. I cleaned out a lot of dirt from behind the black gasket in front of the drum, but the spots just keep on showing up. Is dirt backing up from the line that goes to the drain? Is there dirt in the drum somewhere that I can remove? Thank you
  • vjlowe Feb 06, 2010
    How would a five-year warranty help with a ten-year-old machine? So where is the transmission located that it can leak into the drum? Does the transmission account for all three different kinds of soiling? The brown spots looked like the sandy dirt I got from around the gasket, and the little black streaks looked like a pen (but no pen found in the washer).
    My concern is from how far away will a repairman have to come to replace this transmission, and how expensive might it be? Is the transmission a sign the machine will be developing more and more problems and should just be replaced? The closest repairman might be in Odessa, TX or El Paso, TX . . . the first is 150 miles away, the second is 200 miles. And is the guy going to have to come once for a look, and then come back again with the transmission? I don't mean to sound like an airhead, but it gets complicated living in the middle of nowhere when repair people charge mileage. Is it SO likely to be the transmission that I could tell him to bring the transmission with him, or could it remotely possibly be something else?
    Sorry for all the questions, I just want to be sure I am doing the best thing in the most financially feasible way.
    Yes, it was very helpful to know that A. this is symptomatic of the wearing out of the transmission, B. replacing the transmission would not change the fact that the machine is old and this is just the first sign of its inevitable decline, and C. that given my remote location and the cost of the repair, I would most likely be better off just getting a new machine. Certainly it will be better to get a new machine than to remain in constant fear my clothes could be ruined, because at this point I had already stopped washing things I didn't want to risk losing. Thank you to taran 2005.
  • 10,515 Answers
The only place that grease or oil comes from in a washer is the transmission.Unfortunately you will need to get the transmission replaced.Check your use and care guide it may have a five year warranty.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 06, 2010
  • taran_2005
    taran_2005 Feb 06, 2010
    Thanks for your response!!
    BINGO!! You got it Correct. This is a Common Problem with Almost all washer's of that age. This is a Situation where Transmission started to Fail and the Rollers Worn Out.The grease that you talked about is always an indication of Failing Transmission and you would see more and more as the Transmission started to fail.The Streaks could be caused by worn Support glides and and allows the clothes to get streaked from the
    metal grindings where the drum has been rubbing.
    In short Words, i am sorry to comment - It is Better to Purchase a new Washer than Repair it. It is not economical to Replace Transmission. You could search on google and you would be surprised to know, that this is SO COMMON and yet no solution than replacement of Transmission.
    Let me know, if needed further assistance.
    Hope i helped you.
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Brown spots on clothes
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Jul 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Brown streaks on clothes
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Clothes are dirtier after washing...
The problem with your front load washer is a broken rear bearing. If you remove the rear panel, you will see brown "gunk" all over.
If you want to repair it on your own, order this:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF1240AS0-%3d%3di407639&PartID=407639
Good Luck!
Feb 01, 2009 | Frigidaire GLTF1240A Front Load Washer
go to your local appliance store and ask for "Affresh" washer cleaner. works excellent. If hubby need to get into the machine have hime clean out the pump. You probably have **** in there thats also contributing to the problem. good luck
Jan 26, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Laundry tub
The problem is detergent spotting, do the hottest wash for several occasions and add a cleaner descaler preferably two mugs full of washing soda. Regards Advisor
Aug 23, 2007 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing Machines Logo
176 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
