Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Wont start. sprayed stater fluid but wont stay running
    President:
  • 2,030 Answers
Your carb needs cleaned out. Tke it off and clean it out well with a good carb cleaner and you should be fine
Posted on Feb 06, 2010
10 HP B&G engine starts but will only run with full choke on. whats the problem?
Posted on Mar 03, 2010
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
I have a UST GG7500 Generator and it will not stay running.
Make sure there is enough oil, some generators wont start when oil level is low to protect from damage. Also have you cleaned the fuel injector, they get dirty and clogged just like a car.
Dec 28, 2012 | Computers & Internet
I have a 96 olds delta, start it up and it wont stay started. could it be the fuel pump?
Yes, it could be... Remove the air cleaner hose and spray WD40 or starting fluid in the hose that goes to the engine...Have someone start the vehicle.. Spray short bursts into the hose while car runs.. If it continues to run while you are spraying and then stops when you stop.. you probably do have a fuel issue.. Hope this helps..
Aug 18, 2011 | Oldsmobile 88 Cars & Trucks
Parked the truck and now it wont start,,new fuel pump/filter.will run for a min if sprayed with starting fluid but wont stay running yes has gas in it 1995 chevy s10 4 cyl
check change the fuel filter and check the vacumn to the fuel pressure regulator also check the fuel lines to make sure one isnt collapsed as well
Jan 21, 2010 | 1995 Chevrolet S-10 CA Edition
89 ranger i was driving than it just stalled. i have spark, i have fuel but no fire. but it wont start, if i put starting fluid in the intake it will run for a second then stall.
If you can keep spraying staring fluid and it stays running then the fuel pump is no pumping. only with a pressure gauge can you test it
Nov 26, 2009 | 1989 Ford Ranger
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
460 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
