Question about Kenmore Washing Machines
Water is dripping once wash is done - Kenmore Washing Machines
  • 155 Answers
If water is dripping into tour machine after it has finished your hot or cold inlet valve is faulty turn of each tap to valves one at a time to see which one is faulty when you find it replace it in the mean time turn both taps of when machine not in use hope this helps let me know how you went
Posted on Feb 06, 2010
Water keeps dripping into machine when washing is done
Water entering the machine when it is off likely means you have a failed solenoid on the water inlet valve. It is possible that low water pressure could cause it but if your machine fills normally during use, then the water inlet valve needs to be replaced. It is a simple job if you would like instructions.
Mar 06, 2015 | Washing Machines
My washer will drip water back in the tub after complete washing is finished Why Help
If the water is dripping in from the area where it normally fills for a wash cycle, then you probably have a problem with the water valve. You can open them up to see if debris has made its way into the valve, but they normally are not real expensive and it may just be easier and less hassle to just replace the entire valve. Hope this helps!
Feb 18, 2015 | Maytag Washing Machines
How do i stop water from dripping into basket when the machine is off
Needs a new water fill valve inside of machine
the part where fill hoses from water supply connect to washer is the valve , this valve is stuck open by ethier mechanical failure or sediment from well water , ethier way the water inlet valve needs to be replaced.Once replaced water supply to washer should be turned on when wash is started and turned off when the washing chores are done.
Aug 29, 2014 | Washing Machines
Water dripping from the bottom of the door
Hi Iyle Sponheim - From where the leakage is occurring, the washer door needs adjusting done as soon as possible. Either the door gasket is not securely sealing or the door itself is possibly damaged. Connect with a professional to move forward accurately to properly assist with the repairs.
Jan 31, 2013 | Electrolux EW1000i Front Load Washer
Water leaks into my smartdrive 058 machine throught the wash cycle and when the machine is switched off.
you need a new water valve for the unit. The solenoid is getting stuck in the open position (at least partially) and allowing water to continue to come through even after the water valve is no longer energized. This can be caused by normal wear and tear or sediment from your pipes getting stuck in the valve. This is especially true if you have well water or have recently had any plumbing work done in your house like a new hot water heater or something like that installed.
Nov 16, 2012 | Fisher and Paykel Washing Machines
My whirlpool estate top load washer ( model tawb600jq1) serial cro708750 type 110 has a very slow drip that begins during the wash cycle and continues after washing is done. How can I fix this?
Water valve is bad most likely. Once the machine gets going in final spin shut off the water supply till you can get another water valve.
This home video of mine shows the basic location of your water valve:
Sep 09, 2012 | Whirlpool Washing Machines
Water drips into the tub when the washer isn't running
Your solonoid is in need of a service. Tilt the washer sideways after you unplug it and remove the water pipes. Once disconnected, undo a nut or two holding the plate in position.and remove water valve from machine. Possibly you can remove both water pipes from the valve assembly without going in from underneath. Once loose, use appropriate screwdriver or socket spanner and carefully strip the valve. Clean dirty area untill all particles are removed. reassemble and retry..
May 05, 2010 | Maytag PAV2300 Top Load Washer
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag Insignia hot water dripping only (5 yrs old)
sounds like the diaphram in the water inlet valve is going on the hot water side. you need to replace the whole valve. turn off water and remove hoses. remove the housing that holds the valve and remove the valve. replace and reassemble.
Apr 07, 2008 | Washing Machines
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
