Question about Kenmore Washing Machines
The knob that chooses the cycle is stripped and it doesnot click to start the cycle. The washing machine is 20 years old and very reliable. This is my only problem. Should I just buy a new one or fix this? Living in a warm climate I do a lot of wash. Need advice ASAP. Mahalo, Toni
  • 129 Answers
You can replace the knob easily and with little cost. You will need the model and serial number of the unit.You will also need to know exactly what parts you will need to completely repair your unit. The older machines are very well built,and dependable.Usually inexpensive to use for many years.
Posted on Feb 06, 2010
Sped Queen motor overload
It's 20 years old and you want to repair it?
Mar 19, 2014 | Speed Queen Washing Machines
Replaced water pump on whirlpool cabrio washer now making popping sound during wash cycle
Those washers are trash...they are cheaply made and are not reliable as old washers are...this is why i urge everyone to fix there old washers because its impossible to find reliable appliances anymore. it sounds like a stripped/slipping gear drive system to me, which is typical of those washers...
Mar 10, 2013 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
We replaced timer and lid switch but my machine still doesnot advance goes through wash cycle but will not go to rinse and will not spin if i turn knob to spin. i can hear lid click when closing it but do...
I had the same problem and had to replace the lid switch 2 times before it started working, those switches are junk and unfortunately you can not bi pass that one.
May 17, 2011 | Kenmore 24032\24036 Top Load Washer
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
20 year old front load white westinghouse washer goes into spin cycle when knob is pointing to wash cycle
20 years old? And you expect it to still be working?!? You can't even get parts for it anymore.
Oct 19, 2009 | Westinghouse Washing Machines
Program knob on GE washing machine not functioning
The teeth on the knob are gone. You need knob. Pull knob out (on pos.) look down on knob& in see clip push clip off to remove knob. Need screw driver
May 05, 2009 | GE WJSR2070B Top Load Washer
Noisy wash cycle
if it's 10 year old it's not worth repairing if the transmission is bad.  However, if it's only the $20 coupler that connects the motor to the transmission.  Fix it.
Mar 29, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag commercial washer gets to spin cycle and stops
It sounds like your timer is defective
FIX
When the machine gets to the rinse cycle slowly advance the setting to manually advance the timer
if it just sits bang on the panel or around the knob and listen if ou hear the timer start ticking you will need to replace it
Timers are avaliable from appliance parts suppliers around $29 you can get someone to install it or if you are handy can do it yourself
good luck
Nov 18, 2008 | Roper RAS6233KQ Top Load Washer
Kenmore Series 90 Washer dial isn't calibrated correctly
push the knob to off and turn knob only to you left...off is in..always unplug unit first
Nov 03, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
