Question about Maytag Refrigerators
How to remove and replace water filter on a french door/bottomn freezer frig?
  • 254 Answers
Filter should be in upper right hand corner there should be a drop down tap that will drop down that cover that hides the filter once dropped down u will see filter u can remove it be turning it out ,,,,,,there is no need to turn off water supply as unit does it internally,,remove filter probably a ukf8001, look for a part number on it and purchase one most local appliance stores would stock that filter,,,replace it and u should be set hope this helps
Posted on Feb 06, 2010
Water will not dispense.
have you try replacing the water filter if that does not help check your water solenoid valve.
Feb 22, 2015 | Maytag (MFI2568AEW) Bottom Freezer French...
FGHB2844LF water dispenser not working
Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
How do you change the water filter on Maytag MF12568AES?
Check top right inside of frig. Filer is inside the housing; open door turn filter counter-clockwise, the housing should allow you to lower filter to change it out. Place new filter, turn clockwise, push back into place and close door.
Apr 19, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Sam Sung French Door Refrigerator RF267 After one month, water dispensing slow, small ice cubes, cloudy water. What is the solution?
It sounds like the water filter needs changed. Yes I see It's only been one month. Also make sure you have good water pressure to the frig.
I hope this helps.
Aug 23, 2010 | Samsung RF265AA Bottom Freezer French Door...
My water dispenser does not give me water
1st make sure you got water to the frig.
defrost the frig by turning it off for 2 days with the doors open. Sometime the water freezes inside the door and the water dispenser doesnt work. the turn back on and see if you have water. every 6 months you should change the filter (it could be the problem too)
Mar 27, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Sudden lack of water pressure on filtered water in door
ck the water inlet valve . it has screens in the inlet and if lime / rust / and other meterial build up on the screen . . the wall shutoff may also be at fault . and if frig has been moved it may be parked on the plastic line .. hope some of these hepped ..mm
Jan 19, 2010 | Maytag MFD2560HES Bottom Freezer French...
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
No water and ice cubes
Check the water valves in back of frig. and see if working.. make sure you got a water supply valves may be plugged
Oct 05, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
