The tv works normal except the picture appears bowed, and words on the screen on the left and right sides are distorted. I have gone to the screen settings page and alligned the green, red and blue but dosnt fix the problem. And if I go to the advanced convergence page you can clearly see the graph display lines on the left and right are bowed towards the center. There is a yellow cross you can move around the graph but dosn't do anything. What else can I check or do?
    Problem Solver:
  • 16 Answers
This is a convergence failure --you will need a technician to repair the circuit
Posted on Feb 06, 2010
My tv went from being normal to crazy in the matter of a couple of minutes. It appears as if the picture is bowed. And you can see the words comcast 4 times on the screen all in different colors.
Go to Menu then setup,If you do not see Convergence on the menu then problem is in the Deflection Board,Located on the bottom Left hand side.
Over on the Right hand side of the FBT flyback transfomer is 3 Fuses in a Roll FL231
they will be small rectrangler looking caps but are Fuses it will be the one in the Middle 0.06amps.
Mats Electronics 1-800-628-1118 you can take a pair of needle nose plyers and pull Top OFF of Fuses. You will also need to resolder all the pinns on the FBT.
Jul 06, 2011 | RCA R52WM24 52" HDTV Projection Television
The words "Digital Noise Filter
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Check in the tv menu look for the OPTION go down look for PROGRAM TITLE DISPLAY to turn it off.
Jan 31, 2011 | Samsung LE40R74BDX 40 in. LCD Television
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
BOWED IN SCREEN/PICTURE
the problem is called pincushion
usually fixable not by anyone without electronics background
guessing around $150 you have to decide
as long as it has a good clear sharp picture its worth it
Dec 20, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
RCA Model Number R52WM24
Is this a projection set? If so you simply need to set the convergence. Otherwise I would try to return it to the retailer and exchange for different manufacturer.
Apr 22, 2008 | RCA R52WM24 52" HDTV Projection Television
Zenith rear projection tv 56"
You have a convergence problem. Go to the convergence menu or consult the owners manual on the convergence procedure and try to correct i if you can.. However if the red image is bowed and or not linear you will probably need to call a technician to repair your set. Most likely the red convergence output chip has failed. This is a common problem with all CRT ( picture tube) rear projectors. Good Luck. Happy Easter
Mar 23, 2008 | Zenith R56W36 56" Rear Projection...
RCA D52W20 52" TV AUTO CONVERGENCE WON'T COMPLETE
Sounds like your convergence chip has gone bad. Usually costs about $300-$400 to fix. I would call a local TV repair shop and let them give you a free estimate.
Jan 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
