Question about Corel Paint Shop Pro 9
I GET A 1554 ERROR WHEN i AM TRYING TO LAUNCH PAINT SHOP PRO PHOTO X2
  • 581 Answers
Photo Explosion 4.0 is compatible with Windows 7. but not your version unfortunately.
you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
If the compatibility is not successful, then try and run the Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking the Start button.
Then click Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Posted on Feb 06, 2010
Downloading Corel Paintshop photo x2 ultimate
if you know how to work torrents, heres the link for the download
http://kat.ph/usearch/Corel%20Paintshop%20photo%20x2%20ultimate/
Oct 19, 2012 | Corel Paint Shop Pro Photo X2 Ultimate
When I load paint shoppro x2 it closes worked fine
try to clean your registry or try to reinstall the software it may have some corrupted files
May 06, 2010 | Corel Paint Shop Pro Photo X2 Full Version...
Trying to install on new computer
On CD or back of packaging. If you registered it, e-mail or call the company. They will accomodate you.
Apr 20, 2010 | Corel Paint Shop Pro Photo X2
Paint shop pro x2 ultimate upgrade wont rum on Vista Home
I havent actually solved the problem but I did get PaingShopProUltimate to run by starting up in "SAFE MODE" I tried it out and everything seemed to work ok. but of course this is not very convenient.
Sep 05, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
PSP X2 stopped launching
When it gets to the 2 second point just leave it at that and eventualy, Takes SEVERAL MINUTES, the finish screen appears. patience is rewarded,
Jul 06, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
Paint Shop Pro Photo x2 won't launch
http://www.symantec.com/norton/support/kb/web_view.jsp?wv_type=public_web&docurl=20090319114809EN&ln=en_US
This web-site offers a fix for multi programs effected by Norton 360, it zapped my corel paint shop pro photo and corel support was worthless, it happened when Norton up-graded my program. MFinSOBs.....
Apr 11, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
PSP X2 Ultimate Not Responding
Hi, I got a fabulous response from Corel and it fixed my same problem! Here is what they sent me. The first step did not work alone, but may have been necessary for the second step to work properly. Good luck!
We are working on a permanent fix for this issue. Use the following workaround to allow launching of Paint Shop Pro Photo versions X1 or X2:
Delete or rename the Paint Shop Pro Photo XI database file: ImageDB.db.
Database file locations
On Windows XP: C:\Documents and Settings\<username>\Application Data\Corel On Windows Vista: C:\Users\<username>/AppData/Roaming/Corel Here are instructions to easily delete the ImageDB.db file.
  1. On XP systems, Go to Start | Run. On Vista systems, Click on Start button and then highlight the "Start Search" field.
  2. Type %appdata% and click Ok (or push Enter on keyboard on Vista systems).
  3. Double-click on the Corel folder.
  4. Delete* the ImageDB.db file and then close this window.
You should now be able to successfully run Paint Shop Pro Photo. *NOTE: if you receive a message that the file cannot be deleted or is in use, Restart the computer, then immediately try deleting the file. It should delete fine after a restart.
If Paint Shop Pro Photo X2 still hangs or is slow responding, try the following: Do the following to delete the Paint Shop Pro Photo X2 Database files. The program will recreate the files upon next launch. First Close Paint Shop Pro Photo X2 if is it running.
  1. Go to Start | Run, Type %temp% and click Ok. (on Vista, click Start button, then highlight Start Search. Type %temp% and then push enter on keyboard)
  2. On the Windows® Explorer Tool bar, Click the Up Folder button. The Up Folder button looks like a folder with a green arrow pointing up. If you don’t see it, Click View | Go to | Up one level. (On Vista, click Organize | Layout | Menu bar. Once displayed, go to View | Go to | Up one level).
  3. Double click on the Application data folder. NOTE: The Application Data folder is a hidden folder. Make sure you have enabled viewing of Hidden files and folders to see this folder. We have included instructions* below for enabling this view.
  4. Double-click on the Corel folder.
  5. Delete all content in the Corel Folder and then close this window
  6. Try running Paint Shop Pro Photo X2 again and note how it functions.
* To enable viewing hidden files and folders do the following:
  1. Go to Tools | Folder Options.
  2. Click on View tab.
  3. In the large white area marked Advanced settings, check the "Show Hidden Files and folders" radio button.
  4. Click OK to accept this setting. You should now see the Application data folder as described above.
Dec 02, 2008 | Corel Paint Shop Pro Photo X2 Full Version...
COREL Paint Shop Pro PHOTO XI
where can i download corel paint shop pro 2 user guide?
Jun 11, 2008 | Corel Paint Shop Pro Photo X2
Corel Paint Shop Pro 9 Logo
147 people viewed this question
Top Corel Computers & Internet Experts
Martin Murray
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
