Look for a button on the remote that says "Display" and when Input appears remove it with that button.
SD TECH
Yes, you should if it is the set be able to remove it with the remote for the set with the display button; If you are using a direct TV box it may also be coming from that---try the "Display" button on each remote one at a time---either it is the set or the box causing it to show.
Did you try to remove it with the TV remote?
SD TECH
Is there not a way to get it to not pop up every time you change the channel? It appears right in front of the the description for direct tv every time and you can't see what is on direct tv. It is very annoying!
