Question about Ovens
Model GBS307PDQ5: Oven preheated to 425 degrees.
Model GBS307PDQ5: Oven preheated to 425 degrees. Then tried to lower cooking temp 350 using the up and down keypad. Placed pizza in oven; oven somehow went to clean mode and door locked. Pizza caught on fire; could not turn oven off, could not open door. Opening 220 volt breaker did not turn off top element. Let it sit for about 15-20 min. Oven then turned off, door unlocked. Now all functions work ok, but neither element will heat. I believe, but not sure that I saw a malfunction code F3. Not sure, however.
Thanks for your help.
    Sergeant:
    Champion:
  • 263 Answers
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Posted on Feb 06, 2010
My Kitchenaid Oven doesn't allow me to set a temperature higher that 350 degrees. Electric oven. For example, i will punch in 425 and the panel will default back the temperature to 350.
350 will be the design max for your oven unless the handbook says for your model is higher rated and is faulty
repair or replace with a higher rated temp oven
Nov 07, 2016 | KitchenAid Ovens
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
When using the BAKE setting, the desired temperature is input and the oven begins a preheating phase. The temp will only rise to one degree less than the desired setting, and the oven never reaches the...
more than likely there is an issue with one of the temp sensors. you will need to press and hold clear then upper on off at the same time then release them then immed. press clear 3 times and hold on the 3rd till the service screen appears. on the right side you will see internal temp and catalyst temp they should be equal or very close. ill bet one of them is alot higher than the other if so the sensor will need replace but depends which one is bad as there are 2 of them. if the problem is on the lower just repeat above but use lower instead of upper
Dec 07, 2010 | Miele H398BP2 / H398B2 Electric Double...
Amana oven doesn't heat
IS it gas or electric? If it's gas, you may need to have a technician regulate the air and gas. If it's electric your t-stat may need to be replaced. Hope this helps! :>)!
Aug 14, 2009 | Ovens
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
Gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Frigidaire Ovens
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ovens Logo
205 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
