Question about Refrigerators
I had to remove the door and disconnect the water line on my maytag side-by-side refrig to get it in the house. I can not connect the water line now. Is there a special tool to clamp the water line back together?
    Sergeant:
    Champion:
  • 263 Answers
Yes, you can get a plastic 5/16" union connector for that.
refrigerator repair Orange County, CA
Posted on Feb 06, 2010
Need to remove doors from a Shelvador side-by-side fridge to get into house.. How to disconnect water line to door?
Most of the water lines have a quick connect fitting down at the bottom under the unit. Open doors, remove kick plate and follow line back. Should have a connection in that area.
Aug 18, 2012 | Refrigerators
Water dispenser does not work
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Jul 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No water will come out of the door
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR41X10173 to stop this freezing and it comes with instructions .
May 25, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
May 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
Mar 04, 2010 | GE Refrigerators
Water dispenser does not dispense water GSS25LG
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 , with installation instructions , to keep this from happening again .
Jan 19, 2010 | GE GSS25LGM Side by Side Refrigerator
Our water dispenser on our GE side by side refrigerator quit working. I changed the filter. No results.
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the water line in door is frozen , GE has a heater kit , pt # WR49X10173 , for this particular problem . It comes , with installation instructions .
Jan 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side by side is not dispensing water, have removed the line at door and there is not water coming out. What do I do next.
If the door line is frozen , GE has a dispensor heater , pt # WR49X10173 , to help eliminate the freezing of the line .
Dec 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our water dispenser stopped working we can hear it click but water will not come out?
At the bottom of the freezer door ( remove the kick plate by removing 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If frozen , GE has a water dispensor heater , pt # WR49X10173 , to keep this from happening again . Also , by turning the dispensor light on , for several hours , so it will heat the spout , has worked for several people .
Dec 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
RE: GE model #gsh25jsrf ss. The water does not dispense from door. Can I fix this? Thank you.
Oct 31, 2009 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
