Question about Mitsubishi WS-55511 55" Rear Projection Television
Blue screen On my a cable I only get a blue screen and sound unless I hit the pip input then I get a picture but cant get rid of the pip box please advise Thanks
jomaru
  • 337 Answers
SOURCE: Blue screen and sound but no picture, except in PIP mode
The lighting possibly damage the tuner of the set,for now you can swap the pip with the main picture and change the channels with the vcr,you need the assitance of a service to diagnose how much damage is there but.Let us know what you find or if you nned more information.
Posted on Oct 06, 2006
snakehead
  • 1074 Answers
SOURCE: blue screen
check the agc circuit it is becomming defected.good luck.
Posted on May 18, 2007
  • 20 Answers
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Posted on Sep 08, 2007
  • 927 Answers
SOURCE: mitsubishi ws65613 no picture or sound, blue screen only
Good Day;
Blue screen that has gotten worse over the past few days, I would suspect fluid on your signal board.
The three CRT's in the TV has coolant that tries to keep them cool but they have a problem with the 'glycol' leaking out of it's chamber.
Take speaker grill off, remove panel and look on the right side of opening. Look for fluid on the board, shinny substance, it's hard to see so look closely. That is the most common problem.
2&3 are the CRT's or the CRT's drive circuit.
Good Luck, Day,let me know, Big Irish.
Posted on Jun 18, 2008
  • 927 Answers
Good day, Bgchzy;
This model is known for the tubes leaking fluid, glucose, on the PCB. Check the front of the chassis for said fluid, it may be only a drop, so look closely.
To fix, after TV has no power, try cleaning the board with cleaner and brush, let dry. I suspect this because of multi unrelated problems.
Posted on Jul 17, 2008
No picture on main screen
Sets with PIP use two tuners--one for main and one for PIP---likely the main got hit with the static discharge during the storm----Here we always disconnect both power and cable when a storm.
There is a way around this (will lose PIP) with a cable box connected to the audio and video inputs on rear of set---bypass the tuners and use the box to change channels and provide signal.
let me know if questions.
Nov 07, 2012 | Televison & Video
How do you get the picture in picture to work? What two sources can you use, a cable box and what?
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Let's say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected that's not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables; these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by their Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
Sep 14, 2011 | Vizio VF550M 55 in. LCD HDTV
I have the 2000 Sony Trinitron model KV 27FS16 tv the picture in picture popped up on the screen cant get rid of it. I don't have the original remote anymore. Please Advise
Hello
To turn the PIP feature ON and OFF press the button marked PIP on the remote contro. Each press will get it vanished and reappear. OK.
May 08, 2011 | Sony KV-27FS16 27" TV
A black box pops up on the screen and can not get rid of it unless you start hitting buttons. this only happens at certain times and program lock is not engaged.
It is probably the PIP (picture in picture)
Get into the pip settings.. You should be able to resolve it there..
Have a great day !
Oct 06, 2009 | Televison & Video
Screen is black on my Samsung LCD TV
Press your input button for the correct input your using for cable or viewing regular channels.
Apr 14, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
How to work viewsonic remote
Hi red recruite,
I am happy to help.
The blue box is the Picture in Picture function. Press the PIP button on remote till gone.
The No Entry Sign on the inputs is because nothing is connected to these inputs.
Unless  I an mistaken you have only a HDMI cable connected.
Let me know if I got it right and please rate this solution. Please keep in mind that Thanks For Trying rateing is negative.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 28, 2009 | ViewSonic NextVision N3260W 32 in....
Hi, The quetiopn is about SONY DVD home theatre system DAV-HDZ235. For some reason I have big black box on a TV screen at time DVD playing. The picture appears and box dissapears when I pushong volume on...
Thanks for giving me the opportunity to help. Sounds like you are inadvertently activating P.I.P (picture in picture) with your remote. Perhaps the P.I.P button is next to the volume control. The black box you mention, is a blank channel. That means the way you have your cable box set up, there is no signal coming in to that p.i.p. tuner. Press the P.I.P. button and see if that's what's happening.
If this advise helped you, please give me a rating so I can make my boss happy! Thanks for using Fixya.com
Jan 27, 2009 | Sony HOME THEATER SYSTEM System
PIP
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Oct 11, 2008 | Vizio L37 Television
No pic/sound on main screen
I will recommend replacement of the main tuner
Dec 10, 2006 | Toshiba CN35F95 35" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
