Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Everything looks and sounds like it is working, seals are good but refrigerator and freezer will not get cold.
  • tdfam2 Feb 06, 2010
    The compressor seems to be running(although sounds different). The evaporator and condenser fans are running. The evaporator coils and all copper piping are not cold. I tried to find defrost timer and I believe I found it. It looked like a defrost timer but only had 3 terminals with 3 wires hooked to it. It was located in the top left corner of the refrigerator compartment. There was continuity between the middle(third) wire and second wire but not first. This will be the third refrigerator failed in this house. I think we get too many power surges even though I have a whole house surge protector on my circuit breaker. We have to replace our compact fluorescent light bulbs Could it be a bad capacitor? I've had to replace one twice on my pool pump motor. How can I test capacitor?
  • 4,070 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Place a probe on each terminal. The multitester should display a reading of zero ohms. If the overload protector does not pass this test, it should be replaced.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Feb 06, 2010
  • Charles T Nevin
    Charles T Nevin Feb 06, 2010
    If the compressor is running, you should be able to feel a vibration, and the condenser coils near the compressor are room temp then there is a problem with the compressor or freon. A tech is needed to determine which and to fix leak, capture the freon and recharge the system.
  • 10,515 Answers
Hi, There are few Steps that you could Verify and narrow down the problem :- 1. Compressor - Make sure that the Compressor should be working. When you ON the refrigerator, you could hear a clicking sound from the Compressor.Compressor could be Hot but not enough to lay eggs on it. Note - In case, you find that the Compressor is Clicking and Shut Down the machine every now and then, more often that's an indication of Faulty Compressors. With most Brands, they do come up with 5 Years Warranty. 2. Make sure all the Fans are Working. I have seen many times, that the Fans are not working and the people are Inspecting other Components in the Refrigerator.They should also be running at Optimum Speed. 3. Do you see any Ice in the rear of the Freezer? More often - Frost. ( Not Crystal Clear ). If yes, take a Blower / Dryer and melt it. You would see a complete Difference. 4. Make sure that the Condensor Motor is working. If you could hear Condensor Fan is running, it always indicate that the Motor is Fine too. 5. How many times we never clean up the Evaporator Coils? We are using it for Years and we never clean it. So, if this is the Case, time to Take a Vacuum and clean the Evaporator Coils. 6. It could be a Defrost Problem. There are many Components but How could you make sure? The Best Way - Disconnect the Power Supply and Unplug the Cord. Take everything out of the Refrigerator. Keep the Doors Open for 24 hours. After 24 hours, plug in the Cord and then Turn ON the refrigerator.If you see that there is Some improvement, more likely you have faulty Defrost System. 7. On other Occasions, i have Found Overload Relay to be one of the reasons. I solved many Problems where the Customer Actually Test and Find that the Overload Relay is at Fault. Note - There could be Freon Leak or Gas Leak which i am not considering right now. You need to contact a Licensed Professional t check these. Hope the above information might have Helped you to Fix the Problem. Thanks a lot for taking your Valuable Time and Reading this. Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Feb 10, 2010
    Thanks for your response!!
    More often it is Relay.Do you hear any Buzzing noise when you ON the Refrigerator?
    If Yes, you could unplug the relay i believe its almond or beige in color shake it if it rattles the fuse in the inside has busted.it happens during lighting thunder or just a regular power surge.it burns to avoid damaging the compressor.
    Let me know, if needed further assistance.
    Hope i helped you.
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Freezer and frig not as cold
It sounds like the heater that automatically defrosts the unit may have failed. Before calling service I recommend checking the following: all door seals, make sure they are closed and sealing properly, also the condenser coil either on the back or bottom of the machine should be vacuumed out regularly to get rid of dust buildup. If that's all good it may be the defrost heater and if you're handy you can look up on youtube how to replace it or call a professional.
Nov 28, 2017 | Roper Refrigerators
Samsung RB1955SW refrigerator is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 07, 2010 | Samsung 18.8 Cu. Ft. Bottom-Mount...
Temperatures not staying cold, then getting too cold. First everything in freezer thawed out. Then, fridge wasn't cold enough. We moved everything to freezer just to keep colder (not to freeze). Then, days...
assuming fan now working. clean out vents/ drain holes (make sure no ice in bottom of freezer or in fridge unit)i.e. a total defrost.then check door seals all okay(no air leaks) if unit was trying to defrost itself and you reset to colder it will need to reset itself.....
Feb 11, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer and Refrigerator wont get cold
Good day,
Looks as if you covered most bases.
You didn't say if the fan motor in the freezer compartment is running. Open the freezer door. You should be able to see and hear it. if not, remove the rear panel in the freezer and inspect and replace if needed. If no luck here......
Based on everything you said, it sounds as if you have a serious problem with the sealed system which includes the compressor.
You do not recharge a refrigerator. You fix the leaks, and then recharge. But it could be a restriction in the internal system, or possibly bad valves in the compressor.
In either case, you'll need a qualified tech to sort it out.
Thank you for using FixYa.
Jan 20, 2010 | Kenmore 63093 Top Freezer Refrigerator
Our Crystal Cold propane refrig freezer unit keeps everything frozen but the refrig portion isn't keeping things cold and we've had to throw out a bunch of food. Any suggestions on what the problem could...
I am working on similar problem on my Crystal Cold refrigerator. I've found the seal between the  main door and the refrigerator body is starting to gap. We've also recently noted a few small flies in the frig. To diagnose, I took a butter knife and gently tested small gaps in the seal and found the ones on the lower left of the door (facing the frig) went all the way through. I'm on line now looking for a good price on new seals. They may be as much as $100. I may, if I can't get a better deal try some foam rubber window seals, the kind that comes in small rolls.
Aug 19, 2009 | Refrigerators
Everything freezes in bottom of refrigerator
Check that all seals are completely sealed, especially the freezer door. If the freezer door leaks, the bottom of fridge will constantly be cold. Also, check the flap in the inside back. It controls the air between freezer and fridge. It may be putting more air flow to fridge rather than freezer. The cold air will sink low and keep the drawer are colder.
May 05, 2009 | Whirlpool Refrigerators
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
106 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
