Question about Denon AVR-2308CI
Denon AVR-2308 CI Crackling Audio and suspected overheating
My audio begins to get the crackling audio sound after a few minutes of use. To troubleshoot the problem, I switched to another mode such as tuner or DVD and get no audio sound at all. I turn the receiver off from the mode I had it on with no sound for about 5 minutes. When I turn it back on from standby the audio that previously didn't exist comes on with no other settings changed. It's almost as if it's overheating and the audio begins to suffer. After the cool off the audio comes back and sounds good for another few minutes and then develops the crackling sound again. What's wrong??
  • 1 more comment
  • sxracer91 Nov 03, 2008
    I have the exact same problem, but with a Denon AVR 1708. It starts to crackle (on all modes) then some heavy pops and after that a high-pitch tone starts. It is back to Best Buy for the 2nd time in a month. If problem persists, Best Buy says Denon has a "no-lemon" policy and will replace after so many fixes. I just hope my speakers can hold out till then.
  • Anonymous Feb 24, 2009
    Did changing the Amp solve the problem? i have the same problem.
  • rayrosado Mar 28, 2009
    Denon AVR - 1908 cracking in speakers started after about 3 months of use. At first it was just a little crackling and would go away. Now crackling followed by high pitched whining noise. Removed all connecions and hooked up receiver to different set of speakers....same issue. Happens in all settings (tuner, dvd, etc).
4 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Posted on Apr 11, 2009
housejess
  • 317 Answers
SOURCE: Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Posted on Nov 04, 2009
SOURCE: I have a denon avr 2308. The sound stoped working
i was just wondering if you ever got this issue resolved; i'm having the same problem.
Posted on Sep 06, 2010
There is a crackle when i turn the volume knob.
First unplug it. Sounds like you need to spray some tuner cleaner in the pots that are crackling. Pull the knob off and you should be able to use a spray can of tuner cleaner with the straw that comes with them to spray into the potentiometer , then rotate the pot several times while it is still wet. After cleaning them all, wait 10 minutes and then try.
Jan 09, 2014 | Marantz Vintage Model 2220b Stereophonic...
When on FM tuner, stereo stops playing after a few minutes
Right then sounds like the connection from the aerial lead into the receiver - check out the socket where the aerial plugs into!
Is it loose at all or could there be a bad connection inside the unit.
Get the cover OFF and investigate yourself before you rush down to that very friendly repair man along the street.
Jan 05, 2014 | Denon DRA-365R Receiver
My father has a Dynex LCD TV, Model DX-37L130A11 Rev A, sticker says 10H07-Rev A. Manufactured August 2010, Lot #: 205204 XHT 100453. A few days ago he said the audio started emitting a loud, cracking...
It sounds like you've done quite a bit of troubleshooting, which I applaud you for doing. Have you tried power cycling the TV? Simply turn off the TV, unplug it (and any components connected to it), then plug it back in and turn it on after a minute. See if this corrects the issue. If it doesn't, then I would recommend calling our Product Support team to schedule repairs at:
U.S., Canada, & Puerto Rico - 1-800-305-2204
Mexico - 1-888-882-7326
daily from 7 am - 12 am CT.
Sep 04, 2013 | Dynex Televison & Video
My lg plasma tv has sudenly when i put it on crackles and sound goes i switch it off and leave it for a few minutes and the sound comes back on
Rice Crispies? We hope not. You may also want to check your connections for security. Switch out your audio cable (s) to rule that out. If that does not correct the issue and your settings are standard, you may need service. ^CL
Here is the link you may visit for service assistance:
http://www.lg.com/us/support/repair-service/find-repair-provider
Apr 02, 2013 | LG 42PX5D 42 in. Plasma HDTV
Protron tv crackling sound
The speakers that are inside your tv are damaged and needs to be replaced, after you replace your speakers, the Sound will return at the correct factory settings from which you received your tv..
Feb 10, 2013 | Protron PLTV-37 37 in. LCD Television
What is wrong with my Samsung HLS42WX/XAA everytime I turn it on after ten minutes the volume start making a loud crackling sound then there is no volume sound at all. What do I need to do to get this
It clearly may be a sound problem in the set but a few things you might check, First of course is do you have this issue on all inputs including the rear ones, does a DVD player connected to a rear input do this or not?
If you have a box connected to this set unplug both the box and set from power for a while, cannot hurt but may help.
If using a box and set does not do this with a DVD it may be possible to get around the problem.
A box or even the tuner in the set may be the cause==your tuner not only processes regular signal but also develops the sound signal, it may be bad.
Dec 23, 2012 | Televison & Video
I plug my guitar to the amplifier and i get no sound at all..... only if i press the tunning button turns on & stays on for couple of minutes and then it goes off again....what can i do? P.S.: The...
The tuner on this is weird. It requires three presses of the tune button. Read your manual... One press turns on tuner and passes audio till it times out. A second turns on tuner and kills audio... the third press restores audio... Others have had the same problem understanding this three mode thing and the timeout in the first two modes is confusing when sound disappears.
May 14, 2011 | Takamine EG340CLH Acoustic-Electric Guitar
My Denon AVR589 just started crackling like rice krispies, I've tried resetting the microprocessor, but no luck it still crackles. Is my unit fried?!
Is the sound from the unit itself (airborne) or is it through speakers only?
If the former, turn it off and take it to a tech to figure out what's sizzling in there.
If the latter, is it specific sources and/or specific speakers?
Mar 15, 2011 | Denon AVR-1508 Receiver
when using an hdmi input, make sure the "input mode" is in 'hdmi' or 'auto'. i am sure you can remedy your issues with a trip through the setup menu. it very extensive. good luck
Feb 10, 2010 | Denon AVR-2308CI
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Denon AVR-2308CI Logo
546 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
