Question about Frigidaire Side By Side Refrigerator 26 Cu. Ft. FRS266ZDSB
Freezer compartment thaws out
About every two to three weeks after the drawer fills with ice it starts to defrost and thaws completely everything in the freezer compartment why is that.
  • Frigidaire Master
  • 3,740 Answers
Hi and welcome to Fixya. Once the defrost cycle is started it deos not terminate until the 60 Deg. F thermostat closes and advances the defrost timer to start the compressor. If the 60 Deg F thermostat is not functioning correctly or intermittent the unit will continue in the defrost cycle by powering the defrost heating element. Essentially what it will do is act like a food defroster vs a freezer. This is not a difficult or expensive repair.
I would recommend that the defrost thermostat be tested for proper function. Personally I would just replace it and return the unit back to normal service.
Additionally it is possible that the defrost timer could be hanging or sticking in the defrost mode.
Should you call a technician to repair the unit I am sure he would recommend the replacement of both the Defrost timer and the 60 Deg F thermostat.
I would also recommend the same to you during in home repair service. Thanks again and hopefully you understand why it is performing as it currently is.
Posted on Feb 06, 2010
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Roper RT14 series - Ice build-up in freezer compartment
You are having an automatic defrost problem. there are 3 components in that system and it could be any one of the 3 .
There the timer (most common) heater, and the bi metal terminator the heater and bi metal can be tested with an ohm meter and the timer if mechanical can be rotated into a defrost
Mar 23, 2014 | Roper Refrigerators
Auto-defrost refrigerator freezer ice build-up
Check vents/grills to make sure they are dust free. May need to be replaced. In meantime, leave freezer door open to thaw away ice (remove food not wanting to get thawed)
Mar 06, 2014 | Kenmore Refrigerators
Freezer moisture overflowing into refrigerator
your drain is clogged, defrost the freezer and locate the drain either on the back or in the bottom of the fridge and clean it out. the water is coming from when the fridge goes into defrost
Sep 24, 2009 | Refrigerators
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
Hello, we have a three year old LG GR-359SQ Fridge freezer. Firstly, everything works fine with the unit but at the bottom of the freezer compartment is a 30cm x 30cm by 10mm deep trough that in a space of...
Try adjusting the levelers on the bottom I like to see 1/4 bubble on a level if you don't have a level no problem just so it slopes to the back. good luck Tom
Jul 02, 2009 | Freezers
I have a Kitchen Aid side by side KSRS25IL. The ice maker after
Sounds like you need to defrost.
if you can move everything out unplug it ,turn it off w/ doors open,you can put pans of hot water in the freezer to speed up the process 12 to 24 hrs this will free up any clogged tubes.After its completely defrosted Only turn it up to 4 or 5. Good luck.
Len West
Feb 27, 2009 | KitchenAid KSRS25IL Side by Side...
Freezer Drawer Stuck
Our 550 bottom freezer drawer froze shut earlier this week and the motor made an unusual sound, like it was working too hard. Two of us eventually were able to open the drawer to find that it had frozen shut due to a leak which filled the ice tray solid and then adhered to the actual door, freezing it shut. We emptied the fridge and freezer, turned the control dials down to 0, but neither the motor nor the light would go off. We finally killed the circuit breaker to get the appliance to shut down. It's cleaned and defrosted and we noticed that the gasket has torn in three places, two on the fridge door and one on the freezer door. The freezer door could be from our tugging, but the refrigerator door is normal wear and tear. We filled the tears with some kind of putty and when it is dry we will start everything up again. This is not the first problem of this nature we have experienced with our subzero 550, but it is the most dramatic. Each previous time we have called a repair man out and he has been unable to fix it.
Aug 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Fridge motor is very very noisy
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
Sep 29, 2006 | Hotpoint FFM90 Bottom Freezer Refrigerator
Frigidaire Side By Side Refrigerator 26 Cu. Ft. FRS266ZDSB Logo
255 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
