During a tv program or dvd playback, a pop-up appears saying !tv speakers activated due to systems communication failure. later says audio system active.
    Brigadier General:
  • 8,546 Answers
Make/Models of everything, please. How audio is connected exactly.
Posted on Feb 06, 2010
I have a sb wa340 active subwoofer. I have subwoofer and speakers but I don't have DVD how can I use this
So is the DVD part missing? There is a VCR / Aux input on the back but it is for audio only. There are no video inputs so if the DVD is not included in your sub/speaker system, you'll be limited to audio only. First, you'll need to connect a TV to your system using one 'Video Out' cable methods so you can see the menu for the remote control changes on the system. From here there are 2 options:
  1. Connect up a working DVD player directly to your TV using the best option available. Use the audio outputs on your TV to connect to the VCR or TV input on the system box. (Using standard RCA cables.) You may need to enable the external audio outputs on the TV. (Check the setup -> audio menus etc.)
  2. You can use this as an audio amp by connecting a RCA cord from the a DVD R/L audio outputs to the VCR-Aux input on the amp box. You will need to run a separate video feed from the DVD directly to your TV. (Select the desired input on the TV to watch a DVD.)
You'll need to do a lot of switching back and forth with multiple remotes to get everything working, but the speaker setup can be made useful if it still works.
Here is a manual for the system: http://service.us.panasonic.com/OPERMANPDF/SCMT1.PDF
Mar 13, 2015 | Audio Players & Recorders
No audio on VGN-FE780G, symbols indicate everything is fine
right klik on system tray bottom right on ur screen on the speaker icon ,
left klik on playback devices
make ur speaker icon the default player,
done,
Mar 29, 2017 | Sony VAIO VGN-FE780G Notebook
Samsung HT-X50 DVD Audio Problem
I had this same problem and checked all of my cables and wires. Come to find out one of the wires that connected to the central audio speaker (the one that the audio track comes from) was unplugged. I plugged it in and that fixed it! My audio track is back! So make sure that all of the speaker cables are properly connected! That might be the source of your troubles!
Apr 19, 2009 | Samsung HT-X50 System
HDMI Communications Failure?
Hi
Did you ever get this resolved as I have the same problem
Jan 09, 2009 | Audio Players & Recorders
Compatibility issue: Sony BDPS350 Blue-ray & Yamaha RX-V1700?
HDMI compatibility issues continue to plague the industry and this more than likely is the problem. There are a couple of ways around this.Some people insist on "hot rodding" the dvd and tv by hooking up directly to each other avoiding the receiver all togeether (I do this).But you lose functionality and it makes things more complicated for other family members. Your best bet is to use RGB and Digital audio cables.You won't notice any quality loss and there is a possibility it will look better.
Dec 29, 2008 | Yamaha RX-V1700 Receiver
Audio and DVD playback problems
Hi, sorry for the difficulty in using the system. I will advise you reload the operating system again. Make sure it's from the real manufacturer, I mean don't go for pirated. If it doesn't work, then back up your files and folders and format the system. I wish you the best.
Dec 18, 2008 | Dell Inspiron B130 Notebook
New hp dvd writer... no sound from dvd's
First double click on speaker image in right corner of your screen to see if you have MUTE disabled for all the devices and you have audio drivers to have speaker activated. Second, if you recently istalled new dvd driver it can be hardware problem. There are audio plugs (analog and digital) on back of DVD-Burner. Check if they are connected properly. Third your DVD-playback software might not supporting audio, so you might be missing audio codecs to playback DVD-audio. It depends which program you using. Maybe you need to download another program to playback DVD, for instance Windows Media Player 11.
Good Luck
Dec 13, 2008 | Computers & Internet
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Intermittent popping sound
Its due to earthing leakage! Get your Earthing wiring checked by electrician! then your system will ROCK!
Dec 08, 2007 | Logitech Z-540 Speaker
206 people viewed this question
 Grubhead
Grubhead
