Question about GE Refrigerators
How do you change the filter on my ge refrigerators model number GSS25JETBB?
  • 254 Answers
Locate the filter look for any part numbers on it, some common ones are the oil can one a MWF, or a GSWF, MSWF, which are longer filters..
remove cover if its a long one in corner and twist or turn it out..
if it is an oil can style just remove by turning it out..
there is no need to shut off the water there is an internal shutoff .
replace filter and u should be set ,, hope this helps
Posted on Feb 06, 2010
I have a refrigerator that uses the GE SMART filter. When the filter needs to be changed, the water stops working. I changed the filter -- still no water, yet it makes ICE....any thoughts?
The water valve has two sides. One side is for the ice maker and one side is for the dispenser. If the dispenser side fails you have to change the complete dual water control valve. What is the model number of your GE Refrigerator? Sea Breeze
Jan 10, 2013 | GE Refrigerators
We have a GE Profile, sise by side refridgerator . we need to change the water filter, but can not find the filter on the machine. where is it please?
hello js... go to searspartsdirect.com
Enter the model number and you will see a full set of schematic parts diagrams for your fridge. This way you will see exactly what you have and can even order a new part if you need to. Joe
Thanks for choosing Fixya!
Dec 30, 2010 | GE GSS25LGM Side by Side Refrigerator
Water from dispenser comes out very slowly and takes too long to fill up a glass
The PSW26P comes with a water filter in rear right hand top corner of the fresh food section. Some have a digital diplay for changing filter. Most times that is what begins (water flow restriction) as the filter expires its usefulness. If you have recently changed the filter then we need to have a look at the water control valve on the rear of refrigerator. Look around the door and confirm that model number. I seem to only find numbers like this=> PSW26SGPASS I will return with a link to a photo, Thanks, Sea Breeze
Feb 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
Express Thaw comes on when refrigerator door is closed
We have a GE Profile side-by-side refrigerator which we purchased in 2002, Model PSS25NGNACC. Today we had a repairman come to investigate why the Express Thaw 3lb. light was on and could not be shut off. If shut off, it came on again when the door was closed and reopened. The repairman called GE and learned that this light was an air filter change indicator which turns on at some interval (2 years, they said, although we don't remember ever seeing this before). The air filter involved is for the interior of the fridge and is not critical. GE said that newer master control boards have this function disabled, since people rarely changed the filter and GE no longer makes them. I have read our user manual cover to cover and find nothing on this filter. I guess we just have to pay the $70 dollars to have someone come and call GE to figure it out. But, enough of that. To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps:
Adjust Freezer Temp (Warmer)
Express Thaw
Adjust Refrigerator Temp (Colder)
Lights and functions should return to normal.
Feb 11, 2010 | GE Refrigerators
How do I change the water filter on GE side by side TFX25CRWW?
Here is a link to a free downloadable owners' manual. Go to page 6 for complete instructions on how to change the water filter...
http://genet.geappliances.com/DocSearch/pdf/49-6953.PDF
Sep 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE CONQUEST HOW TO REPLACE FILTER
Because I did not get your model number I have a lot of different ways of changing filters below, Please rate my solution and click on link, Sea Breeze
http://www.youtube.com/results?search_query=whirlpool+refrigerator++&search_type=&aq=f
Aug 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from Water dispensor
Have you checked your water valve? I dont have your model number but you could have what you call a double water valve and one side of it may be out, alternately you may need to change your water filter if you havent done that yet. I have seen were the water stops dispensing first and then stops making ice. have you changed the filter lately? If not change it then if that doesnt work check water inlet valve...
May 12, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
The warning light to reset filter came on. I've
Resetting your Refrigerator filter indicator light after changing your water filter Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Once these two steps are completed, you are all set to enjoy great tasting ice and water through your refrigerator. If you don't see your manufacturer listed or the insructions don't work for your model please post a comment with your make and model number so that we can provide exact instructions for your model.
May 06, 2009 | GE PDS22LBN Bottom Freezer French Door...
Water from Ge profile refrigerator tastes bad so does ice where can I find the filter? Model #TFH30PRT
The water filter for this refrigerator is optional. The GE part number is: WR97X0214, or one of the box stores also carries a universal filter. Just make sure it for a ¼ inch line. The water filter is located on the back side of your refrigerator, and will have to be pulled out from the wall. Use caution not to break the water line when pulling/rolling it out.
Apr 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
