Question about Kenmore Refrigerators
My compressor is running hot on my fridge i have cleaned the coils , what else do i need to do? I have even pulled the fridge away from the wall.
  • 454 Answers
Why do you think the compressor is running too hot? It is normal for them to have some temperature, as they are compressing a gas, which increases the gas's temperature (and consequently the compressor's). As long as the compressor gets adequate air circulation and the coils are clean, there's nothing else you can do.
Posted on Feb 06, 2010
New Hisence fridge freezer noisy and hot
for the noise check the compressor groumits
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
the reason the outer side of the door seal area is getting hot is the compressor is over heating, probably the condenser fan motor to your compressor is bad.
It should be a little warm but not hot. they don't use heaters anymore ( some older models still use heaters) around the doors, instead they use the condenser coils to remove condensation and moister, you might want to check your condenser coils on the bottom or back of fridge to see if they need cleaning
If the condenser coils/condenser fan are all plugged up they need cleaning and/or the condenser may fail or has failed..
The ones that use an electric heater will have an "energy saver" switch that will turn it off.: God is the reason I give you free advice so God is good!
Dec 24, 2016 | Refrigerators
Hot spots on outside of Amana fridge. sxd22s2w model
if it feels like it's running hot check the coil to see if it needs to be cleaned,remove the bottom kick plate and look at the coil,the coil should be cleaned once every 6 to 12 months,also pull the fridge out,remove the back bottom panel,make sure the condenser fan is blowing and vac out any lint near the fan and compressor,also check the cover that you removed and clean that too.you might want to unplug the fridge while you clean back there so you don't hit the fan blade,wait 5 minutes before you plug it back in so the compressor can reset itself.there are gas lines that run through the frame of the machine,if the coil is jammed with dust and lint the machine runs hotter,this is how it cools off through the condenser coil and the fan blows the air around to help cool it down,if it runs hot then the freon will run hot and you could feel it on the frame and in the strip where the doors close together.you can buy a brush that you can push into the holes of the coil to pull the dust out or if you have a shop vac you can vac out as much as you can and then put it on blow and blow the dust out of the coil,just hit it with short bursts or the dust will blow everywhere.
May 22, 2011 | Amana Refrigerators
The side wall of the fridge and the wall betwen freezer and fridge is hot, very hot.
clean the coils and make sure the fan by the compressor is running fast enough . this will cause the unit to run to hot if dirty and the wall between should be hot it has a hot tube running through it .. but if comp is too hot so is the wall ..mm
Aug 10, 2010 | Daewoo Refrigerators
The door frame of the refrigerator gets way too hot. the lady said it burnt her finger it was so hot. its a maytag msb2354grq
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Here's how to test the fan.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 21, 2009 | Maytag MSB2354G Side by Side Refrigerator
Center support is hot
Pull the fridge out from the wall , and remove the rear panel . Check to see if the fan which cools the compressor is running . If not , it will have to be replaced . You may can get it started , by turning the blade by hand , but , it will still have to be replaced as it will stop again . If it is turning , your coils need to be cleaned of dust , lint , pet hair , etc . Also , the fridge has to have a back panel , so it will pull air over the coils and compressor , to keep them cool .
Aug 23, 2009 | Whirlpool Refrigerators
Freezer is cold... fridge is not
Could you pull it away one more time and feel the compressor to see if cool, warm or too hot to hold your hand on. That tells me a lot of things. I want to see if your compressor is shutdown, running but not cooling or trying to start and cannot. That will help me to answer what we need to do next. Sea Breeze
Aug 19, 2009 | Refrigerators
Every thing in our freezer is melting and the fridge is barely
take the back cover off and then clean the condenser coil on the unit. that will lower the head pressure whiuch in turn will lower the suction temperature.
Mar 28, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Side by side refrigerator by whirlpool
try vaccumming under your frig coils, and pull away from the wall and clean under there too. i would check to see if the fan behind the unit is spinnig( its suppused to cool the compressor) if its not youll need to replace that.a pretty common problem easily fixed
Oct 25, 2008 | Whirlpool Refrigerators
Whirlpool Side by Side - Overheating
HI thanks for your question. the heat between the two doors is normal. its heated there to stop moisture, from hitting a cold surface , and turning to water, so its normal. but pull fridge away from the wall. remove the back panel by the compressor. clean all coils. thanks the appliance doc. please rate my answer. thanks
Oct 13, 2008 | Whirlpool Refrigerators
Refrigerators Logo
81 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
