Question about Onkyo TX-SR500 Receiver
How can i reset my onkyo tx-sr500. and get it out of protection mode
SOURCE: stuck in protect mode
i believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
Posted on Dec 11, 2008
SOURCE: Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
Posted on Sep 05, 2007
jeesusfreek
  • 18 Answers
SOURCE: Onkyo TX-SR500 loosing settings
Turning any receiver off will erase the settings - there is no backup battery (Onkyo uses Battery Free Memory Backup) and the length of time depends on the capacitor charge. Why not just leave the receiver plugged in? Stand-by mode uses a negligible amount of power - enough to keep the capacitors charged and the LED on the front panel on.
Posted on Jan 28, 2008
SOURCE: How can I reset my Onkyo TX-SR601? Hard reset...
Hold Video 1 and Press the power button then turn it back on i had the same problem
Posted on Mar 11, 2010
SOURCE: How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
Posted on Jan 29, 2011
I have an Onkyo TX-SR500. I turn it on, and immediately it shuts off. Under troubleshooting it says, "activated amplifier protection circuitry". Here is my issue: I've called Onkyo USA...
No one would be able to troubleshoot it over the phone or internet. Take it to a reputable shop and get an estimate, then decide if it's worth the cost.
May 17, 2011 | Onkyo TX-SR500 Receiver
Hi, after i turn the power on and then press the stand-by button, it clicks off to stand-by mode instantly. This is an Onkyo TX-SR500
This indicates that the system is going into protect mode. First disconnect all speaker wires (with the power cable disconnected). Then turn the unit on and see if it sill shuts aff ofter a few seconds. If it does not, then you have a problem with the speakers or speaker wires. inspect the wires at both ends for frayed strands that may touch. If that all lookd good, plu the speakers in, one at a time, until the problem reappears. Be sure to turn the sytem off before plugging in any speaker just to prevent any accidental short which could be catastrophic. If the system goes into protect mode with all speakers disconnected, you probably have a shorted output transistor.
Apr 05, 2010 | Onkyo TX-SR500 Receiver
Onkyo tx-sr500. No output to surround speakers.
Need to be diagnosed my serv tech. This could be many thing. Most Onkyo receivers have 3 year warranty.
Mar 25, 2010 | Onkyo Audio Players & Recorders
Onkyo TX-SR500 5.1 Receiver Last night
1-disconnect subwoofer first and test-and then disconnect surround speakers-and front speaker after-and later center speaker.ever time you disconnect you check the operation until you find the bad one(or two)which make the problem change its cable first and then change speaker itself.if all above failed contact the service center.
Jul 04, 2008 | Onkyo Audio Players & Recorders
Tx-sr500 receiver
Hi,your fears are confirmed... the protection circuit is self resetting, and is operating because the amp will most probably have blown that channel as a result of the speaker wire short. At the risk of doing more damage(in the workshop,we always soft start an amp with output problems to prevent more damage)you could take the lid off, check and replace any blown fuses, be sure to use the same rating and type. If the problem persists, or the fuses fail again, it needs some expert attention. Off to the repair shop.... Good luck, and thanks for checking with FixYa
Feb 16, 2008 | Onkyo TX-SR500 Receiver
Jan 27, 2008 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 Receiver Logo
621 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
