Question about Brother MFC-5460CN All-In-One InkJet Printer
Test color gives green not yellow - Brother MFC-5460CN All-In-One InkJet Printer
    President:
  • 2,017 Answers
Kindly change the catridges may be it is low.
Have a nice day and do not forget to rate please...!
Posted on Feb 06, 2010
Wiring problems with Kia stereo
The simple solution would be to go to the source where she bough the system
Dec 11, 2014 | 2001 Kia Spectra
Wrong Color Printing
Type "print nozzle test" in the search box and click Search. Perform a nozzle test, and if the colors match what are on the instructions, your print head and inks are OK.
(1) If the print head and inks check out OK, type "wrong colors on print" in the search box, and you will see several troubleshooting steps you can try.
(2) If the nozzle test colors are off, confirm that you are using BCI-6 inks for all three colors and the small black tank. You should only have a BCI-3 tank in the large black position. If you have all the correct inks, your machine probably needs to be serviced/ repaired.
Thank
Jan 09, 2014 | Dell 1320c Laser Printer
Only printing Yellow
Sir/Madam
Please See The Vedio On Youtube
By This Time i Fixed My Problem,
HP 2500 color only prints yellow
or
Follow Us On
HP Printer Support
Jan 08, 2014 | HP LaserJet 2550n Printer
Won't respond to computer, light on printer alternates flashing between green and yellow
  1. Start with the printer OFF
  2. Hold down RESUME button and then hold down POWERbutton
  3. release RESUME button
  4. press RESUME twice, then release POWER
  5. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Press 2 times for EEPROM reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Jo
Feb 19, 2011 | Canon i850 InkJet Photo Printer
I have Boxer AT bike, I want to know that bike's speed meter indicator has three type of colors, up to 50 Kmph green up to 70 or 80 yellow and upwards it has red. Why this different colors used?
Up to 50 Kmph green =GIVES GOOD MILAGE(gives 50km/l)
up to 70 or 80 yellow =drinks little petrol(gives 40km/l)
and upwards it has red=drinks your petrol (gives 35km/l)
Sep 22, 2009 | 2005 Bajaj CT 100
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
We can not print the green color in my graphics
Get new cartridges. Refills only work a few times then the jets then to dry up.
Apr 28, 2009 | Office Equipment & Supplies
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Yellow is a greenish color
Try printing this test pattern. I got this from this other website. But as ridiculous as I may sound, did you put the yellow cartridge into the Cyan compartment? Because to produce green you need to combine yellow and cyan. This test pattern will tell you which colors are not working properly. Then we can trace which cartridge is the problem or not. Let me know the colors that come out.27dfd86.jpg
Jul 22, 2008 | Brother MFC-410CN All-In-One InkJet...
Brother MFC-5460CN All-In-One InkJet Printer Logo
53 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
