Hi I have a msi notebook ( ms-1221) it seems to be stuck or sleep mode or it could be the fingerprint scanner.Baught this notebook on ebay the lcd was broken I have replaced the screen and now I get no display even when i try to use the hdmi port when trying to bootup. not sure if it locked or broken
  • antomul Feb 06, 2010
    Hi
    I can hear the system trying to boot up and the green light for the standby/sleep stays on as I am unable to see what is on the display or even when I try to use an external screen/hdmi/vga would this fingerprint password be post boot up or the bios ??
  • antomul Feb 08, 2010
    How do I locate the memory ???
  • 2,404 Answers
Open the laptop back up and make sure the lcd cable is connected properly to the back of the lcd and where it connects to the motherboard. This will make sure the screen is hooked up properly.
Also try unseating and reseating the memory one stick at a time in each slot one at a time.
If the laptop is turning on and booting up into windows but your just not getting a display then it could be the lcd you got is defective.
If after doing my steps your still not getting video on the lcd screen or the HDMI outputs, then it sounds like the motherboard is bad.
Posted on Feb 06, 2010
  • Ben Wabnick
    Ben Wabnick Feb 08, 2010
    Hi there, memory should be behind a door on the bottom of the laptop. you'll need a screwdriver to unscrew the screw to open the door.
  • 583 Answers
Sounds like a defective unit. You should get something on the screen if it is locked to tell you to enter a password to unlock (or scan the your finger). The point is, you should be getting some sort of prompt.
  • Mark Tidwell
    Mark Tidwell Feb 07, 2010
    Usually the fingerprint scanner is post bios as drivers have to be installed for it to operate. It sounds like the video "card" is not working. The reason I put "card" in quotes like that, is that usually the video is integrated and can't easily be replaced. Since you are not getting an output on either the LCD or the port, I would say the video card is the root of your problem.
  • Mark Tidwell
    Mark Tidwell Feb 09, 2010
    According to the specifications on this site http://www.msiwhitebook.com/product_spec... , it supports up to 4GB of main memory in two slots. The memory type is also specified there. Usually the memory is located under a cover that can be removed by removing screws on the bottom of the unit (usually marked with a memory symbol that looks like a memory module). I am trying to locate a users manual for you for more information.
MSI L1600 netbook seems to be stuck in sleep mode. The power also cannot be turned off - even removing the battery and replacing it.
try to boot the computer, if you hear the start up sound then mobo is not bad. this issue could be caused due to boot sector viruses as well. see if the back light turns on ..
check the settings in bios and try to run a recovery. if neither helps
call 1-877-805-1027 for expert help
Jul 30, 2015 | MSI Computers & Internet
How to disable the sleep mode of my msi
Hi Tyrell,
Please try to check this website on how to disable sleep mode on your machine.
1. please unplug your notebook from A/C power and remove the Battery for a few minutes and then re-test? If won't work please check the sites below.
How Do Stop My Laptop From Going Into Sleep Mode eHow
How To Enable or Disable the Standby Mode
May 08, 2014 | MSI "MS-U135DX-1679ZA 10"" Netbook, 10""...
Msi sleep state appears stuck
Remove ALL media, DVD, CD, USB, unplug, remove battery, plug in reboot. OR try to boot to safe mode, open the Control Panel, select Power Options, set to High Performance, Change Plan settings, set SLEEP and Hibernate to Never.
Apr 18, 2013 | MSI L1350D-1672US Netbook
How to open a sleep mode msi core 2 duo loptop?
You can press the enter key or the power button, if its not responding you might have to force a shut down, unless you just ran out of battery.
Apr 06, 2013 | MSI MS-145123-001 CR400 Core 2 Duo...
Looking for a display inverter cable for msi megabook s270
Here's an MSI lcd cable but make sure it matches the model number on your lcd cable. It did not say it was for megabook S270 but some other models. Most cables go across different models.
http://www.ebay.com/itm/Original-New-MSI-Megabook-MS-10351-MS-163C-LCD-Video-Cable-K19-3036002-H58-/250966405323?pt=US_CPU_Fans_Heatsinks&hash=item3a6ec370cb
Jun 02, 2012 | Computers & Internet
No display
poss hard drive bad sectors
Feb 08, 2010 | Computers & Internet
No display after repair new lcd
Most important thing is to try and get video but it also sounds like you might be having issues with the hard drive if your trying to install windows and the light for it is staying frozen.
Motheboard is going bad in it if the machine is running normal but you can't get video from the lcd or the outputs.
Feb 06, 2010 | Computers & Internet
I have H P Pavillion DZ6500 which I just upgraded to Windows 7 Professional. The Verisoft Access Manager that drives the fingerprint scanner is not compatible with Windows 7. Any suggestions?
Hi:
I fought the same thing with another fingerprint scanner, and even spent some quality time speaking with Micro Soft Technicians....It seems they are not really supportive of fingerprint scanners,And forget getting any support for Window 7, 64 Bit version. My fingerprint scanners were Microsoft brand, and still no 64 bit support...
Nov 24, 2009 | HP Pavilion tx1000z Notebook
MSI MS-1036 with missing parts
this was i found, where you can get the parts you need for your laptop..
CLICK HERE...
and if you want to see the MSI website there at GERMANY..
MSI GERMANY
Kindly rate my solutions, will yah..?
Jun 21, 2008 | MSI MS-1036 Barebone
Computers & Internet Logo
190 people viewed this question
David Payne
David Payne
