Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
I have a 50'' Sony Wega tv that is 6 years old. I ordered a new lamp for it however we can not find our tv manual on how to replace it. My husband is having a tough time!
  • Sony Master
  • 1,527 Answers
Hello here is my email address superred@talktalk.net i'll send you the manual no charge
regards
shaun
Posted on Feb 06, 2010
My Sony KF50WE610 50" Grand
You just need to replace the lamp, put the model number in a search engine and chose the best priced one for you
Jun 12, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
We bought a new replacement lamp XL2200U for our Sony 60" KDFE60A20 TV, but we need to know how to install it...Please help We removed the old lamp, bulb and casing together, and I ordered the replacement...
Yes, lamp installation procedure is written in user manual of TV and click Sony Support to download user manual copy if required. Lamp replacement is simple process, take out old lamp and slid in new lamp.
Please buy Sony original lamp for TV safety.
Nov 05, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blinking Red Light-50" Sony Grand Wega
It sounds like Lamp is broken in TV and requires replacement.
How old is this TV and did you replaced lamp recently?
Oct 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
How do I replace the lamp in my sony lcd projection tv Sony Model kdf-50we655
TV has 2 thumb screws on lower corners, loose these screws and take off lower front part, there is lamp cover under that removed lower long part at TV front, remove lamp cover, lamp is in front of you, lose its screws and pull it out.
Slide new lamp and put things in reverse order, job is done.
Lamp replacement procedure is also mentioned in User Manual of TV and if you want to download copy, click Sony Support.
Thanks.
Sep 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KF-50WE610 Tv won't turn on, red light blinks 6 times
3 times means Lamp and 6 means you have lost a voltage. You may have a thermal fuse blown.
This set has a common trouble with overheating caused by the drum fan located on top of the lamp housing clogged up with dust. When the lamp is getting old it runs hotter and that combined with the fan being clogged the thermal fuse blows. You must replace the lamp and thermal fuse. You must also clean out or replace the lamp fan. This drum type fan should be cleaned out every year or two depending on the environment.
Apr 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
Mar 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Trinitron WEGA won't turn on
6 blink error is either a power supply (g2 board) or a blown thermal fuse. if it came back on, its not the thermal fuse so you would need a new g2 board. if it blinks 5 times, you need a new ballast (lamp driver)
Dec 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Wega 50
Usually this is a classic lamp problem, but it could also relate to a defective lamp ballast (power supply).
Now if you are replacing lamps frequently, it's likely the lamp isn't getting enough airflow to keep it cool. If you don't get the airflow issue solved it will take out the thermal safety fuse near the lamp and your set won't come on and the power light will blink red 6 times repeating itself until you unplug it. Some lamp fans are so deeply nested it takes a trained tech to get them out. Dusty environments are bad for TV's with fans in them, especially projection types.
Nov 09, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Apr 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
112 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
