Question about Toshiba Televison & Video
Can i convert vcr to dvd with my Toshiba mw20F52? there are instructions for other way around, dvd to vcr, but i would like to put old cassettes onto discs.
I called Toshiba. Combo CANNOT record DVDs, just play them. My misunderstanding. Please cancel my account and remove my info from your database. Thanks in advance, Teletanti
Posted on Feb 11, 2010
I have the Philips DVP3150V/37 DVD Player / VCR Combo. The DVD player works fine, but when putting in a VCR tape, it plays for a few seconds then shuts itself off. Any suggestions on what to to?
The 3150 has two belts or bands that can slip when old, just like the old days. One is for loading the cassette and the other is for providing take-up torque for the tape. Have also seen the tape loading arms get out of sync and don't put the tape around the heads..... working on one now but dont have a fix yet..it has the loading problem.
Nov 01, 2011 | Philips DVP3150V/37 DVD Player/VCR
Our toshiba mw20f52 tv/vcr/dvd won't turn on. It worked fine last night. Is it fixable or dead? Should we try anything in particular to "jump" it? And there are a dvd and a vhs still in it! ...
You may have blown a fuse in which case something else inside is probably shorted. Check diodes and transistors near the blown fuse if you know how. If you're not comfortable working on electronics I would check the phonebook for a hometown TV repair shop. They may be nice enough to retrieve your movies for you at a minimal charge and maybe give an idea of how much to fix the set. Good luck.
Apr 28, 2011 | Toshiba MW20F52 20" TV/DVD/VCR Combo TV
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
I want to hookup my insignia converter box to my dvd/vcr and my tv so I can record programs. What do I need to do. I have a 2 year old Toshiba Dlp and an Allegro dvd/vcr
Cable from wall to "cable in" on converter box.
"Cable out" from converter box to "cable in"on vcr. "Cable out" from VCR to TV "Cable IN" DVD should be hooked to VCR by way of Composite cables Red,Left, Yellow, Video White Right. There you go! THanks, Dana
Aug 16, 2009 | Insignia Digital-to-Analog Converter for...
Conversion of polaroid land camera casettes to vcr or dvd
What lovely memories must be stored. I am quite happy to offer my services to convert these movies to DVD. Whilst most companies would not touch Polavision cassettes, I am able to do this no problem.  Please contact me regarding quantity, etc. and I will give you a reasonable offer.
Dec 05, 2008 | Polaroid Photography
External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Sep 09, 2008 | Philips Televison & Video
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Converting VHS to DVD
All you have to do is buy a vhs to dvd recorder. They sell those everywhere, like costco, walmart, etc. They keep getting cheaper and cheaper...
They will come with a manual with model specific instructions, but usually its pretty easy. The cassette plays and the device records the video onto the dvd.
They also play vhs and dvds too XD.
Here's a good website:
http://hometheater.about.com/od/dvdhardwareandsoftware/tp/dvdvcrrecorders.htm
Jan 06, 2008 | Emerson EWD2203 DVD Player/VCR
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
