Question about Kenmore 22.0 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
I have a Kenmore side by side Model No. 363.9565522. Noticed water dripping out of front of freezer onto floor - this has happened periodically over the lifetime of the side by side. Slid bottom freezer tray out and noticed a sheet of ice on the floor of the freezer. Also noticed ice adjacent to drain hole. I removed all of the ice using hot water, blow dryer, etc. and poured some hot water dow drain hole. Two weeks later, water is again dripping out of freezer. While removing ice again, I noticed small droplets of water appearing (falling) on the back plastic wall above the trough that leads to the drain plug. Not sure if this was because the freezer door was open or another problem. Removed all the ice last night and again poured hot water down plug. It was recommended that I buy a Whirlpool kit. - I called about the kit and will try and pick it up next week - as I understand it, the bar will attach to the heater coil and insert into the drain. Looking at the freezer, I noticed that the ice is building up adjacent to the drain along the trough. I inserted a pipe cleaner down the drain to see if there was a clog, and it went in about 6-8 inches. If the drain is not clogged, then why is the ice building up along the trough? If I buy the kit, should I position the bar outside of the drain to heat the buildup of ice so it will flow into the drain? I've taken pictures, but I don't see how to upload them.
  • sheppardwk Feb 06, 2010
    Thanks.
    Last night, I used a turkey baster and blasted hot water down the drain. I looked this morning and the ice has started to build up again adjacent to the drain and all along the trough. The drain is completely clear, so I'm still puzzled why the ice continues to build up. Someone suggested that maybe the freezer wasn't defrosting long enough to allow the ice to melt. I'll continue to watch it and buy the kit on Monday. Positioning the stem into the drain hole doesn't seem as though that will melt the ice along the trough, but I'll try.
  • Kenmore Master
  • 3,361 Answers
The drain heater goes into the drain,not outside it.
You need a longer drain probe to push all the way through the drain.
Look underneath for a kink in the drain tube.
Posted on Feb 06, 2010
  • steve
    steve Feb 07, 2010
    You may have excess water. Check the icemaker water spout and cuber for leaks.
    You can make a drain heater from a length of bare copper wire. You wrap one end around the defrost heater. The other end goes into the drain hole.
2 Suggested Answers
  • 4793 Answers
SOURCE: Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Model 795.71013.010 drip pan is full and leaking onto floor
Those models have problems with the defrost drain and defrost drain tube becoming blocked. Have you noticed water buildup on the floor of the freezer? See item 105A that is the drain tube.
http://c.searspartsdirect.com/lis_png/PLDM/F1002002-00002.png
That drain may have come unblocked because the refrigerator was off long enough for this ice to completely melt overflowing the ice trough seen in the video.
Appliance 911 Sea Breeze
Sep 13, 2015 | Kenmore Refrigerators
Water is dripping into pan under fridge and overflowing onto floor. looks like water is dripping from filter at bottom. what can i do?
Check to see looks like the container is already full. You have to remove the tray full of water and then insert it again. It will happen again and again ( overflowing water) so you need to periodically check the container pan if water is full.
Also by checking periodically that pan, you will minimize rust build up. You will need to wipe around it with soft cloth or rags so the body of your refrigerator will not decaying due to rust built up. This will destroy the metal parts of the fridge.
Good luck.
Jun 25, 2011 | Kenmore Side by Side Refrigerator
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Feb 04, 2010 | Refrigerators
Drip pan is full and overflowing onto floor
If the temperture behind the compressor is not so hot the water will not evaperate. the heat from the compressor dry out the water.
Jan 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a top freezer model and every morning their is a small pool of water in front on the floor. I checked the bottom tray in the back and drip tube and they seem to be ok. I noticed in the door that...
These doors are not water cooled. Is there water in the drip pan? Likely not and the drain is froze over with ice. you will have to remove the rear panel inside the freezer and clean the drain. There is most likely ice under the freezer floor that needs removed also. Take your time and do not damage the styrofoam separator and air channels.
Eric
Aug 27, 2009 | Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
291 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
