Question about JVC LT-42E478 42 in. LCD Television
My flatscreen tv is distorted
JVC LT-42E478 color is off and picture is destorted.. Can external speakers too close to tv screen cause this? If so is it fixable.. Noticed my vizio has same symptoms but was not "exposed" to as many speakers for as long. I never really noticed my vizio until watching a movie off my computer and the dark scenes were faded then my parents gave me there old tv (the jvc) because it had problems.. I read somewhere the external speakers magnets can effect some t.v.'s if set to close.. My vizio had 2 speakers 1 off each corner and the jvc had all surround speakers resting below tv frame (hence the jvc is much worse) is this a true possibility on why my tv is messed up? If so is it fixable and at what posible cost? Thanks- A.J.
  • chubba87_69 Feb 06, 2010
    The picture is not clear. Still readable but fuzzy. And video game (wii) Is blotchey and colors seem to fade together... There are "pinstripe" black lines (horizontal) the color is way off almost has a hologram look to it. When watching normal tv all the above and white appears hollow and kind of glowing (as if contrass is high or something) Can't really explain that great but basicly the picture is wacko!!!
  • 1,476 Answers
Speakers can cause problems with the correct display of video on TVs but usuall it only concerns direct view tv. Projectors should not have any problems or flat screens. I think you have a different problem Explain better what you mean by distortion in the JVC. Let me know and I will try to help you.
hardrocko
Posted on Feb 06, 2010
  • Kim Yearick
    Kim Yearick Feb 11, 2010
    It sounds like your control board could be bad. Check www.encompass.com or www.shopjimmy.com for the part. The swap is straight forward. Take back off. Locate the board. Remove all screws and cables. Remove and install the new unit. Let me know how you make out or if you need more help
    hardrocko
    Thanks for using FixYa.
JVC LT-42E910 LED flat screen TV, backlight comes on, menu box is displayed but after about 5 seconds backlight goes out. Picture and sound still working but no backlight. How can I troubleshoot?
jvc tv backlight Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
Jan 11, 2016 | JVC Televison & Video
Jvc lt-40fh97 40" LCD Hdtv
You need a repair guy for this one.
Feb 28, 2008 | Televison & Video
Why can't I use the HDMI port on a JVC LT-42E478?
your hdmi is not connected tight or the cable is bad,or it is dirty,use canned air to clean out plug.extend your comp screen to the tv
Jul 14, 2015 | JVC Televison & Video
JVC lt-42e478 HDMI No Program or Weak Signal, AV works {blurry and oversize}
Nope sorry this does sound like your control board is naffed and needs replacing , it sees the avi as no rf input is needed but will not switch to if to give you vision chroma and sound .
Jul 02, 2015 | JVC LT-42E478 42 in. LCD Television
My JVC LT-37EX17 flat screen TV doesnt have sound?
If the earphone jack works the set is ok---that socket can cause this issue if dirty or worn inside.
Check also in menu internal speakers are not turned to OFF or external.
Dec 22, 2012 | JVC LT-37X688 37 in. LCD HDTV
Jvc lt-42e478 gennessa tv black screen and green blinking light
Start with an examination of the power supply, burnt parts or puffed up filter caps---the set is not making it out of standby to on.
Dec 11, 2012 | JVC LT-42E478 42 in. LCD Television
Black screen in jvc lt 42e478
If you can see a dim image when you look at the screen at a sharp angle then you most likely have a faulty inverter board or faulty CCFL lamp/s.
Most likely faulty inverter board which supplies high voltage to the CCFL lamp/s.
Jan 16, 2012 | JVC LT-42E478 42 in. LCD Television
I have a 42 inch flatscreen tv and I had it to close to my radio speakers and now my color is kinda dark and the faces are green how do i fix that and will it go away
Radio speakers maybe too loud to cause contact resistance to the LCD connector in the circuit. Contact resistance can go as high as 40,000 ohms up from 0.1 ohm. Disconnect and reconnect may reduce contact resistance back to 0.1 ohm.
Nov 20, 2010 | JVC LT-42E478 42 in. LCD Television
WHITE DISTORTED SCREEN
U Main Tuner signal board is dead.Replaced the Main Tuner board will solved this problems.Picture was white distorts,he should of replaced the Main Tuner board.The T-con control board only replaced when u have power to tv,but no video.When have any kind of video on the tv all it way cause by Main Tuner signal board.
Mar 17, 2010 | Televison & Video
Colorwheel?? Tv has bad color and quite blurry on
Based on the Model# provided, your TV does not have a color wheel. Could be one of the PCBs is bad, or even the panel. Have a TV technician look at it.
Good luck
Nour BMI
Feb 05, 2010 | JVC LT-42E478 42 in. LCD Television
JVC LT-42E478 42 in. LCD Television Logo
875 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
