Question about Kenmore HE2 Plus Front Load Washer
Kenmore HE2 - water leaking from bottom - almost like a garden hose? any ideas
  • 254 Answers
Remove panel on bottom usually three screws will remove panel then u can look inside to find leak.. check the drain pump for leaks or debri inside pump by removing cap u willl see down there... hope this helps
Posted on Feb 06, 2010
I have a leak somewhere.where could it come from?
check the pipes from the water main and the pipes in the machine could be a seal has gone
Feb 19, 2016 | Kenmore HE2 Plus Front Load Washer
Tip
I also had problems with my Kenmore HE2 leaking water on the floor. I removed...
I CAME TO THE SITE WITH THE PROBLEM OF MY WASHER NOT DRAINING. I HAVE HAD PROBLEMS WITH THIS FOR MONTHS. TAKING THE HOSES OFF. CLEANING THEM ETC... TODAY I FOUND THE BEST SOLUTION.. THE WOMAN WHO POSTED THAT SHE SAVED HER HUSBAND $300.00 BY TAKING THE BOTTOM OFF WASHER WAS RIGHT.....
BOTTOM OF FRONT LOADER.. THERE ARE THREE SCREWS.. YOU NEED ONE OF THOSE NOT PHILLIPS BUT ROUND LOOKING SCREW DRIVERS(SORRY).. ANYWAY TAKE OFF THREE SCREW.. ONE ON LEFT, RIGHT AND MIDDLE.. THERE IS A WHITE DRAIN HOSE WITH A CAP.. VERY HEAVY PLASTIC FRONT. IT IS HARD TO TWIST OFF CAP BUT KEEP TRYING. ANYWAY IT IS GONNA GET REALLY WET.. SOME WATER CAME OUT AT FIRST BUT I WAS NOT CONVINCED.. SO UNDRNEATH I STARTED TO SQUEEZE THE HOSE AND OUT POPPED 3 SOCKS AND AN ERASER.. THEN ALL THE WATER THAT WAS IN THE WASHER THAT WOULDNT DRAIN.. EVERYTHING WAS SOAKED INCLUDING ME AND MY SON SO BE READY WITH LOTS OF TOWELS. BUT IT WORKED. IM HAPPY TO SAY IM DOING MY FIRST LOAD NOW AND EVERYTHING IS RUNNING BEAUTIFUL...
on Apr 09, 2009 | Kenmore Elite 45986 Front Load Washer
How do you remove a pump from a kenmore he2 washing machine
Unplug the unit! If you have a base take the unit off of it. Lay the unit on its back with the bottom facing you. Should be a cut out on the bottom that you can see and reach the pump. Place bath towels below the pump and around the unit as the hoses hold water. Remove the hoses, bolts and wiring harness from the pump. NOTE: easy off but not so easy to get everything back on. Be careful of the cutout in the bottom as edges can be very sharp!
Sep 25, 2011 | Kenmore HE2 Plus Front Load Washer
No water when I start the machine, kenmore he2 front loading automatic washer model 110.46462500
First are the valves open for the water inlet? Next make sure that your hoses are not kinked. (There are some hoses that will seal themselves if they detect a leak, you may want to replace the hoses.) Remove the hoses from the back of the washer and place this free end into a bucket or sink, open the valves and flush lines of any foreign matter. Next clean the screens that are in the washer inlets. Sometimes you can pull these out with pliers for cleaning. Reinstall the screens and then the hoses. Make sure that there are no leaks.
If the above do not help, then the washer inlet valve is probably bad. See the parts diagrams here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11046472500/0582/0153200?sid=MMLxMerchandizexManualsModelx110.46462500x11046472500 (top and cabinent parts)
The manual for the 110.46462500 is available from Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17838/KENMORE-Residential-Washers-L0521458?brand_name_search=110.46462500 .
I hope this helps.
Sep 18, 2011 | Kenmore HE2 Plus Front Load Washer
The washing maching is leaking bottom right side.
Check the clamps that hold the rubber door boot in place. Also check your hot and cold water fill hoses to make sure they are tight.
Aug 03, 2011 | Kenmore HE2 Plus Front Load Washer
Washer is leaking
sounds like you have a hose problem. are the hot and cold water hose connections tight? they may need new washers. if that is the problem turn off water valves,disconnect hoses and replace them with garden hose washers from any hardware store. re-tighten them snugly. just tight enough so they don't leak. if it only leaks while draining, replace the short hoses connected to the pump,located inside bottom of inside of washer.
Sep 16, 2010 | Kenmore 9781 Electric Laundry Center with...
Leak water from bottom
Please try to use a good lighting to check on the bottom to confirm the exact place of leak. It is possible that the drain hose is damaged or the drain pump is faulty and leaking. If so once you identify the spot remove and change hose , tighten hose clips or patch up the leak on the joints. I don think it will be an issue once you can look into the location and you must see it first. Hope you try. Good day
Aug 14, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
1,233 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
