Question about West Bend 41125 Hand/Stand Mixer
When I turn it on the light comes on but nothing else happens. I just got the mixer and I read everything and got it together. When I plugged it up and turned it on it came on for a minute and then went off. Now when I turn it on the lights comes on but nothing happens.
I have decided to return the west bend stand mixer since it has never been used and get another brand.
Posted on Feb 06, 2010
How can i fix this problem
PDF]SM-70 INSTRUCTION BOOKLET 7.0 Quart Stand ... - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/sm-70.pdf
Cuisinart7. Do not exceed the maximum capacities listed in this use and care instruction book. 8. ... Troubleshooting . ... extra-large Cuisinartâ„¢ 7 Quart Stand Mixer.
Jul 30, 2015 | Cuisinart 7 Quart Stand Mixer
Mixer won't turn on
You will need to test for power throughout the circuit to find where it stops, you will need a multi meter. You may be better getting a service agent to look if you are uncomfortable dismantling your machine.
Dec 21, 2013 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid stand mixer won't start after replacing gear
you either forgot a retaining clip or a pin. because it sounds as though the mixer is frozen completely, it also sounds as though you know how to do a tear down so I would suggest a full tear down and clean to make sure that you do not have metal shavings from the old worn gear that is capable of freezing your mixer, unlikely but it can happen, next is the speed control plate that may be out of tune and needs some readjusting. Let me know if this helps.
Mar 02, 2013 | KitchenAid Food Mixers
Fails to run
The governor should move back and forth as the speed control goes from speeds 1 through 10. It's purpose is to push on the control plate in order to obtain the different motor speeds.
Apr 20, 2017 | KitchenAid K5SS Heavy Duty Commercial...
Just does not turn on. Plug it in and nothing happens
slap it a few times. really. If there is a way you can manually turn the motor, turn it by hand a few times. make sure it is unplugged while doing any of this. except the slappng. Sometimes the brushes don't make goog contact. common problem on new mixers.
Nov 06, 2009 | Kenmore KMX10T Hand Mixer
DONT WORK
Hi. Before you get too far, call kitchenaid parts to find out if they still have parts for your mixer. They no longer show a parts list for the KSM90 so your mixer may end up in the trash.
Go to mendingshed.com and select the Kitchenaid products button then select Kitchenaid mixer parts. Near the top of the page locate the button for the free kitchenaid service manual. Download the manual and read about the disassembly and reassembly of your mixer.
This manual does not cover your mixer but is a usefull tool for working on any mixer. Good luck with it.
If this solution has assisted you, please rate it. ricardok45
Apr 18, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
NO POWER TO UNIT, NO POWER TO SWITCH.
Hi all. Goto mendingshed.com and download the free kitchenaid repair manual for free. These older mixers were well built, unlike the new ones. They are well worth repairing. The repair manual is very comprehensive and will assist you greatly should your mixers need repair at a later date. Good luck!
Mar 29, 2009 | KitchenAid K45SS Classic Stand Mixer
KSM103 won't run
I had removed carbon brushes and when tried to start nothing happened kept removing brushes it eventually started
Dec 14, 2007 | KitchenAid KSM103 Professional 5 Series...
A200T HOBART MIXER
is there a bowl cage on the mixer?if not bypass the timer and see if it starts.
Oct 19, 2007 | Hobart A200 Stand Mixer
West Bend 41125 Hand/Stand Mixer Logo
119 people viewed this question
Top West Bend Food Mixers Experts
tfelton3
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a West Bend Food Mixer Expert? Answer questions, earn points and help others
