Question about Sewing Machines
I need to know the power (wattage) rating or the current draw for a Sunbeam mattress pad and for a Sunbeam Comfortzone Electric blanket. Both are Kingsize. I would like to use the same circuit for something else and need to be able to estimate the various loads already on the circuit. I have 200 watts of lights and 250 watts of a stereo. Can I add 600 watts more on a 20 amp (2400 watt) circuit? The controllers do not have wattage rating marked on them and the blanket does not have wattage marked. I don't want to unmake the bed to see if the mattress pad also has no wattage marked on it.
  • 1 more comment
  • gil_woolley Feb 06, 2010
    I still need to know the wattage rating for the Sunbeam mattress pad and the Sunbeam Comfortzone Electric Blanket. I cannot find their wattage on the blankets, on the controllers nor on the literature.
    Sunbeam Mattress pad = X
    Sunbeam el. Blanket = Y
    Lights = 200 W
    Stereo = 250 W
    Furnace = 1200 W
    Added load = 600W
    My total wattage is: 2250 +X +Y
    And the circuit is rated at 120x20=2400 W
    I measure 120 V at all the outlets.
    I can rewire so that the blankets and stereo move to a different circuit but I still need to know X and Y.
    I need to know the wattage requirements for a Sunbeam mattress pad (heated) and a Sunbeam Comfortzone electric blanket. Both are used
    on a king size bed but the blanket may be only queen size. I am plugging some lights (200 W) and a stereo (250W and run a furnace (1200 W). I want to add 600 W more in floor heating tile mat but am approaching the 2400 W limit for this circuit.
    The controllers, mattress pad and blanket and even the manufacturer's literature do not mention wattage.
    If I know the wattage accurately, I can rewire outlets to different circuits to better balance the loads.
    Any help out there?
    Thanks, the wattage of 200 for a blanket and for a mattress pad is exactly what I needed to know.
    President:
  • 1,185 Answers
The average current draw for a Kingsize blanket is 200W on full setting
The same applies to the heat pad
From your list of appliances the existing circuit will take the load with ease .
I would however make sure that you have the correct fuses in the plug tops and that both heaters are plugged into their own sockets or via a very good quality two way adaptor plugged into a single socket
Posted on Feb 06, 2010
  • Tom
    Tom Feb 07, 2010
    When ratings are given for say a 20 amp circuit there is always a margin allowed to protect the end user
    A 20 amp circuit will take the whole load on a constant basis with the knowledge that there is at least a 25% safety zone.
    Not knowing the layout of your home I do not know what you are plugging in where
    However you could make some changes which will help the situation
    Replace the light bulbs with energy saving versions make sure that none of the plug tops get more than slightly warm when the appliance has been on for say 30 mins
    If possible check that the main fuse on the control box is not getting hot (Switch the power off first)
    A small amount of heat is acceptable because the circuit will be under load , hot fuses equal too much drawn current
    If you can see the wires going into the control panel do the finger test on the cables , they are insulated and it is safe (If there are cracks or breaks dont handle them).
    Genius:
  • 1,341 Answers
Yes you can..I assume you have :
-lights = 200w
-stereo = 250w
Additional needed = 600 w
Total you need = 200+250+600 = 1050w
Now your circuit is 20amps, 2400w max, right?
I assume you are in the US, then voltage = 110v
Thus power= amp * voltage.
Hence voltage = 2400/20= 120 volts...()
Now if your total usage on this does not exceed 2400w then you can use the devices you mentioned on this breaker and it should work fine.
  • heeman mohun Feb 06, 2010
    The best way to work this is to add a different breaker only for the 1200w oven,that is the rest is connected to a different breaker which will make more sense and allow future expansion of appliance rather than being restricted.Hope this helps.
Can't find blanket stitch
Unable to help without knowing the make & model. FWIW, some machines do not have a blanket stitch.
Sep 25, 2016 | Sewing Machines
Replacing clutch type with a variable speed 3/4 hp 400 watt motor. I need a compatible foot pedal. can you suggest one that will handle the wattage
Sewing Machine Foot Pedal - Alibaba.com
www.alibaba.com > Machinery > pedal
804 Results - Sewing Machine Foot Pedal, Buy Various High Quality Sewing Machine Foot Pedal ... Power: 400W Compact AC servomotor(direct-drive system).
Jul 30, 2015 | Sewing Machines
Wattage of pfaff 7570 sewing machine
Check the plate on the unit if it gives you the Voltage and the Current in amps just multiply them together to get the wattage.
Mar 07, 2015 | PfaFF Sewing Machines
SINGER Futura XL-400
230 V @ 50 Hz; 64 W for European version, so 0.27 Amps ; if you're in the US, just call a retailer and ask them to read the voltage and wattage or amperage off the nameplate of the machine. Watts = Volts x Amps. Since US voltage is 110, 64 Watts would mean the machine was drawing about 0.6 Amps. That's assuming it's an equivalent motor to the European version.
Feb 12, 2014 | Singer Sewing Machines
Bernina 1130 need manual for blanket stitch- help please
try these sites
bernina customer service
sewingpartsonline.com
sewusa.com
Apr 05, 2012 | Sewing Machines
Hai I bought kenmore before 2yrs .At that time I was in Us .Later in 2009 feb we shifted 2 India .Now I am living in Chennai,Tamil nadu.Because of volts problem unable 2 work here.What 2 do? should I get...
So your machine is designed and manufactured for 110 volts but India operates on 220 volta at 50 cycles per second. So you will need a voltage converter as well as a plug adapter.
There are three types of Voltage converters:
Resistor-network converters
This type of converter usually supports approximately 50 -1600 Watts. They are lightweight. You can easily use this converter for high-wattage electrical appliances like hair dryers and irons. But, you can use them for short periods only and they are not ideal for digital devices.
Transformers
Transformers support low watt rating, around 50 - 100 Watts. Generally, you can use them continuously. Also, they provide better electricity for low wattage appliances like battery chargers, radios, laptop computers, cameras, mp3 players and camcorders. Their drawback is the low wattage and heavy weight.
Combination converters
Combination converters are also manufactured by some companies. They are a combination of a resistor network and a transformer in the same package. You can easily switch between the two modes. If you need both types of converters, then it is better to buy this combination converter.
So you should check the model plate on your machine and see what the wattage it draws are to ensure you are using the corect type of converter.
Mar 07, 2011 | Kenmore Sewing Machines
Due to illness from a collision with a drunk driver in '90, I had my leg amputated mid April and moved June 30th. Needless to say, I didn't pack each and every piece of equipment. My carefully handled...
its difficult with serial number as model and manufacturer is required. you will have to get the details by local electric appliance store dealing with this products. as they will give you details of the manufacturer by checking the unit make and model. thanks.this will help.keep updated.
Nov 30, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
