Question about Whirlpool Duet GHW9150P Front Load Washer
Front door is locked and I cannot restart machine. Indicator light says "f d/l". How do I unlock the door?
    President:
  • 1,554 Answers
Disconnect the machine from the outlet. Prop up the lower front edge of the machine with a block of wood or cushion the top rear edge with cloth and lean it against the wall. Remove the three screws securing the lower toe panel to the cabinet and pull it down then out.
Reach up and locate the bottom of the door latch assembly along the inside of the front panel. Gently pull down the manual door unlocking tab until a click is heard. Open the door when the click is heard.
Posted on Feb 06, 2010
  • Whirlpool Master
  • 19,396 Answers
Hi.
Before disassembling, please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
I also suggest giving a call to the support number listed on the owners manual first.
The front light lit on my Whirlpool.
Regards.
Posted on Feb 22, 2010
Front loader leaking out the front door as is clothing stuck in it, How can we release the door lock. We've stopped the cycle.
Restart the machine...
On a NEW CYCLE... The first thing the machine
should attempt to do... is to drain itself.
If it does not...
UNPLUG IT... Restart it on a spin cycle ... or regular
wash cycle...
Carnac the Magnificent YZQ7YL
Jan 21, 2017 | Washing Machines
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
How can I lock a renault megane 56 plate without the key card as it is not working
Locking/Unlocking the doors from the outside
This is done using the RENAULT Card; see the "RENAULT Card" information in Section 1.
In certain cases, the RENAULT card may not work:
- if the RENAULT card battery is weak, flat, etc.
- if equipment operating on the same frequency as the card (mobile phones, etc.) is used;
- vehicle located in a high electromagnetic radiation zone.
It is then possible:
- to use the key integrated into the card to unlock the front left-hand door;
- to lock each of the doors manually;
- to use the interior door locking/unlocking control (refer to the following pages).
Using the key integrated in the RENAULT card
Insert key 1 into the lock in the driver's door and lock or unlock. Locking the doors manually
Turn screw 2 with the door open (using the end of the key) and close the door.
This means that the doors are then locked from the outside.
The doors may then only be opened from the inside or by using the key in the front left-hand door. Interior locking/unlocking door control
Switch 3 controls the doors, boot and, depending on the vehicle, the fuel filler flap simultaneously.
If a door or the tailgate is open or not closed properly, the doors and tailgate lock/unlock quickly.
If you need to transport objects with the boot open, the other opening elements can still be locked: with the engine stopped, press switch 3 for more than five seconds to lock the other opening elements.
Locking the doors without the RENAULT card
For example, in the event of a discharged battery or the RENAULT card temporarily not working, etc.
With the engine switched off and an opening element (door or boot) open, press and hold switch 3 for more than five seconds.
When the door is closed, all the doors and the tailgate will be locked.
Unlocking the vehicle from the outside is only possible with the RENAULT card in the vehicle's access zone or using the key integrated in the RENAULT card.
Door and tailgate status indicator
With the ignition on, the warning light integrated in switch 3 informs you of the locking status of the opening elements:
- indicator light on, the doors and tailgate are locked,
- indicator light off, the doors and tailgate are unlocked.
When you lock the doors, the indicator light remains lit and then goes out.
Dec 12, 2015 | Renault Megane Cars & Trucks
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Dec 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Control lock lit, no other buttons work
    Instructions
      • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
      • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
      • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
    Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
    Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
    On My Whirlpool Duet Model# GHW9150PW A setting kicked on that
    May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Door won't unlock and cycle won't start
    The interlock has failed most likely. Its a small electronic part that the door catch connects into when you close the machine door. Its tricky to release but can be done. Unplug the machine, remove the lid, put your hand down the front of the machine to where the door catch goes in and fiddle until it releases. It takes a bit of luck when you dont know what your looking for.
    May 24, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
    Door won't unlock
    try the cancel button it will drain the water and release the lock
    May 30, 2009 | Maytag Neptune MAH9700 Front Load Washer
    Door locked indicator light flashing
    This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
    1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
    2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
    3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
    4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
    Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jan 08, 2009 | Washing Machines
    Kenmore Front Load Washer on the blitz
    remove bottom panel and ck pump for obstruction especially if water is still in tub
    Jul 21, 2008 | Kenmore 43142 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    95 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
