Question about GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator
Door rubber keeps falling off - GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator
  • GE Master
  • 3,740 Answers
Hi and welcome to Fixya. Once a door seal starts coming off it begins to deform and tear away from the mounting points on the inside of the door. Most of the time the only option is to replace the door seal You did not mention if it was the freezer or food section seal that was falling off.
The replacement parts can obtained from this source"
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218035
Freezer section door seal is Item 14 ( there is a 5 - 6 day wait for shipment)
And for the food section door seal (Item 103)
Available now.
Posted on Feb 06, 2010
The black rubber top for the rubber joystick on my wheelchair keeps falling off where can I purchase a new one? It looks like a black rubber nipple
superglue holds rubber to metal very well , just don't use to much to run down inside switch but stays on tip
they now mfg a gel superglue for this very application (no run/no mess)
Jun 01, 2015 | Health & Beauty
Toyota 1995 truck window falls out of the track
try adjusting the felt channels that the window runs in as it goes up and down
put it right up and loosen off the channel adjuster at the bottom
lower the window down slowly and keep the channel tight against the glass edge
tighten the channel bolt
Apr 19, 2017 | 1995 Toyota Pickup
My 1989 buick skyhawlk passenger side window keeps falling its not electric
your window crank mechanism in the door is striped or bent, remove inner door panel and inspect window parts, look in bottom of door for possible parts that may have fallen off. KEEP all fingers clear of moving parts as if the window falls or something you could loose or injure them !!!!!!!!!!!!!!!!! Cant express enough but be careful. I have had cars fall on me, smashed fingers, broken fingers, broken hand, all due to car repairs so believe me when i say a mechanical window mechanism will remove or smash a finger very easily.
Feb 25, 2011 | 1989 Buick Skylark
I'm having trouble keeping the chains on my John Deere Tractor. I put them on exactly how the diagram said. They seem pretty tight but they keep falling off when I get out there during snow removal. ...
you need to make shure the chains fit the tire snug and then you need to put a rubber tension band (they usually don't come with the chains) you can get them at a walmart or auto parts store, about $2 for 2 of them and come with little s hooks that you secure to the chain, instructios are on the package, the rubber band you put on the chains on the outside of chains and it keeps tension on the chains so they won't be lose and fall off. hope this helps.
Jan 12, 2011 | John Deere 22 In. Rear Tire Chains
The bolt on the bottom of the refrigerator door keeps falling out causing the door to fall off.
you need to buy a bolt washer, its a little flat ring that you put in between the revolving bolt and the head of the screw. this will help rotate the screw while keeping the bolt in place therefore preventing it from always falling off whenever you open / close the door
Oct 04, 2010 | Refrigerators
Door keeps popping open
You don't say what kind of refrigerator you have, so this will be a generic answer. You need to replace the door closing cams, which are located at the bottom hinges.
The cams provide a sloping surface or v-shaped notch to lift the door slightly as you open it. The cam's sloping surface causes the door's own weight to hold it closed. If the cam has broken, it can fall out or turn with the door, allowing the door to come open.
The magnetic gasket is only supposed to ensure a good seal, not hold the door closed. You don't need to replace it.
Mar 15, 2009 | Refrigerators
The rubber gasket inside the door falls off.
The gasket will have to be replaced. I've had customers with this problem and the only way to correct it is to replace the gasket
Jan 23, 2009 | KitchenAid 24 in. KUDI01TJ - Multiple...
Missing Rubber Stoppers on Kinderkraft Crib Dreamer No. 305
You can probable just put a nail or srew in for now!
Here is the 800 number for kinderkraft. They have a website but it doesn't appear to be working. 1-800-822-6748
e-mail service@kinderkraft.com
http://kinderkraft.com/main.htm
Jan 13, 2009 | Kinderkraft Vermont Crib
Gluing rubber cover on rear door of Nikon D2x
i have little faith that this can be done, as i tried doing it with epoxy - my favorite, never-fails adhesive - and it didn't work. i think if you can get your camera to Nikon, though, they'll replace the whole door with another whose rubber isn't likely to come off. i read someone online saying they took their D2x in for some other repair and Nikon replaced the door without even asking him...whether they did it for free, i don't know, but i'd hope so, since the rubber falling off in the first place is really their fault.
Oct 15, 2007 | Nikon D2X Digital Camera
GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator Logo
155 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
