Question about Britax Marathon
Britax marathon harness straps
My almost 2 yr old daughter has figured out where the latch to loosen the harness straps is located. While driving on the interstate, I glanced back at her and the whole thing was loose. She was able to pull the latch up and while leaning forward, worked the straps loose. I haven't been able to find anything on this issue and was hoping someone could help me before we go buy another carseat. This carseat was made in the fall of '05.
  • Anonymous Sep 22, 2008
    I have the same problem! We have two Marathon carseats for each of our children, ages 1.5 and 2.5, and both of them have figured out how to loosen the straps and wiggle completely out of the harness! PLEASE, if anyone has a solution, post it!
Same problem posted here:http://www.amazon.com/review/RTJ6ER2E5F8UF
They recommend filing an official complaint at:  http://www.nhtsa.dot.gov
We have same problem...very frustrating!!
Posted on Jul 29, 2008
How to make harness larger
Posted on Mar 15, 2008
My daughter seems to be very uncomfortable when in our Britax Marathon convertible car seat. She cries everywhere we go and tenses up her body and seems to be in pain. We can't figure out what is...
Well the first thing to ask is.....is the seat new, if so did she do this in previous seats. If the issue is new and the seat is one she did not have issues with before you can try to remove the cover to be sure nothing is poking her. Also if the straps are too snug around the thighs it will make for a rough ride for the child. If all else fails return it to the store and dont be afraid to bring her along to "Test" a different seat prior to buying it!
May 08, 2011 | Britax Marathon
Bought used Britax Marathon and Roundabout carseats, without the manaul. Need directions on how to install- rear facing for now, but will need directions on forward facing as well.
Go to the Britax website they have a pretty detailed explaination. Basically use the latch clips put your knee in it and pull tight. where you get the real security is though the tether that comes of the back of the headrest, you attach that to the floor clip in your car or under the front seat if you dont have one.
Nov 05, 2009 | Britax Marathon
How do you raise the shoulder straps up to a higher level on the Britax Marathon carseat?
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Jun 13, 2009 | Britax Marathon
How to loosen the straps on envenflo tribute carseat?
This is about all I could find for you. Hope it helps.
Had one - its a huge pain in the **** and I always busted my fingernails doing it. The metal clips have to slide over the bumps to get them out. I hated that thing. May I make a suggestion? Return it. lol . I'm figuring you got a combo seat - Evenflo Generations, Bolero, Chase, that is a forward facing only seat to 40lbs, or a convertible seat like Evenflo Tribute that is forward facing to 40lbs. Since I don't know her age its hard to make a suggestion, but for just a little more money (we paid $79 for our Chase) you could get a much better seat. If she needs a convertible that will rear face, get the Evenflo Triumph for $150 or less, The Evenflo Triumph Advance (not the original Triumph, make sure it says Advance) is a great seat. $150 version at Babies R Us has padding similar to Britax seats, top slots of 17", harnesses to 35lbs rear facing, and 50lbs forward facing. $120 Walmart version just has little less plush padding. Wide open belt path, easy to install, though it doesn't have built in lockoffs. The harness adjusts at the front of the car seat, you don't have to take the car seat out of the car just to raise/lower the straps. It's one of only 2 seats that does this (The Britax Boulevard is the other, I believE), and it has infinite harness adjustment so the harness always fits perfectly until its outgrown. No more tugging straps to tighten them either. You tighten and loosen the harness using knobs on the side of the seat. As a major bonus, it can be used in a recline position even in forward facing mode. Awesome for kids who still sleep in the car. I LOVE THIS SEAT! LOL My son, who is too big for every other car seat at Walmart has the same amount of room in this as the Britax Marathon.
If she is forward facing (over 30lbs and over 2years old) then a Graco Nautilus would be a lot easier to use and install, $150. Harnesses to 65lbs and then becomes a booster, will be the last seat you have to buy her. Metal reinforced.
Combo seats are usually a major waste of money, as they only harness to 40lbs, no more than most convertible car seats, so you're really not getting any more use out them then the convertible seat.
Jun 12, 2009 | Evenflo Generations
Help with install
Go here to download a copy of the manual.
The straps that are in the area where you'd thread the seatbelt to install are for LATCH installation if you have LATCH anchors in your car - but you can only use seatbelt OR LATCH to install, never both. The strap at the top, with the same hook, is the top tether.
Instructions for using both are in that copy of the manual - the installation instructions for the Regent vary depending on your child's weight, so read it carefully.
Feb 11, 2009 | Britax Regent
Britax Roundabout car seat thigh strap adjustments
Carseats werent made for all the extra stuff we have to put on our kids. So will have to take your little one in and out of the snow siut in the car. I have an auto start button on my keys so I can warm the car before we go out there, so I can take my little one out of his warm wear in the car. Its just a headache putting them back in it once you get to your destination.
Nov 28, 2008 | Britax Eclipse Si - Paris Convertible Car...
Help with install
There seems to be pretty good support (helps prevent lawsuits I suspect) here:
http://www.britaxusa.com/support/userguides.aspx
Sep 13, 2008 | Britax Marathon
Stuck in recline
I know this post is old but I figured somebody w/the same problem might come across this. I had the same problem with my Marathon today. I also own a Roundabout & had no problem changing the recline myself. When my husband came home he took a look & fixed it. All he did was put it in the upright postion , held it in place & turned the seat on it's side & pushed up on the base and it clicked! he pushed on one of the corners (but I don't know if that even matters)
Jan 05, 2008 | Britax Marathon
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Britax Marathon Logo
432 people viewed this question
Top Britax Baby Gear Experts
thegtw
Jennifer Rock
Jennifer Rock
Dorel UK
Dorel UK
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
