No picture,have sound and functions.Prior to no picture, blue sync problems? Now turn on tv blue lamp ''tube'' does not lite up or stay on. Green,red lamp ''tubes'' are on,projection lamps not on?
2 Suggested Answers
texasdan
  • 60 Answers
SOURCE: replacement of the green lamp(picture tube) in a
You can probably purchase a smilar set on Craig's list for $300.00, at least that's what they go for in the Austin Texas area.
A new tube may be too expensive and difficult to replace.
Posted on Sep 13, 2009
Picture stays on for a few minutes then turns off.. what could be the problem? light bulb? can i do it myself?
This model TV is a CRT projection and does not have a lamp. It has 3 CRT tubes (Red, Green and Blue). Unfortunately, you may need to have a trained TV technician diagnose this further.
Nov 04, 2013 | Mitsubishi WS-55613 55" Rear Projection...
I took the back of the tv off and the blue lamp is not bright like the red and green. Could this be a coolant problem or lamp. I have the PT5492S Akai rear projection TV.
The blue is usually dimmer than the other two lens; what I would suggest is try to look into the lens with the set on; BE CAREFUL AND NOT TOUCH ANYTHING INSIDE THE SET.
If the red and green show a picture but the blue looks like a floodlight you have bad Glycol in the blue tube (common in these sets).
If all have a normal picture remember to wipe the lens clean at the top; do not try to take the lens etc apart.
Before you rate this information let me know what you find.
SD TECH
Aug 15, 2011 | Akai PT5492S 54" Rear Projection...
My sony kv-36fs13 picture is very red. I tried adjusting the hue without success. I am getting the little red light on the front of the tv blinking five times. Any ideas?
open the back cover of your TV (unplug the unit) using a soldering Iron,resolder all the components at the CRT socket .the small square board attached to the tail of picture tube That's it! good luck and please dont forget to rate I need it to keep going...
Mar 08, 2011 | Sony KV-36FS13 TV
Good morning, i have a 50'' rca hdtv rear projection.../ and when i turn it ''on'' there is no sound and no picture..but the blue light comes on and then blinks 4 times and the 5th time it stays on then...
You might have a bad lamp. RCA DLP projection That is the most comon problem with them. CRT rear projection, Red,Green,and Blue tubes.If it is the silver one w/the black speaker grill. Chass # _ _ _222 ?
Has 222 in the number.Can be several problems. Many things go wrong in those. Horz. Output,Flyback,And bad soldering are the most common problems w/those. Recomend staying away from RCA. Not the same company they once were.
Jan 01, 2010 | Sanyo DP50747 50 in. Plasma TV
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
CHANGE BULB SOUND WORKBUT NO PICTURE.GREEN LIGHT
If you still have red light , it means the temperature of the lamp is too much. Did you buy the original part number of the lamp.
Jul 24, 2009 | Televison & Video
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
C-Dog
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
No picture coming from red lamp
Sounds like you have two differant problems. A red drive or red picture tube is bad and the conbvergence IC's are bad. To test the red drive disconnect the green picture tube socket BUT MAKE SURE THE SET IS UNPLUGGED!!Then remove the red socket and move over to the green tube. Then turn on the set. If you get the same out of the green then you have a drive problem that needs to be trouble shot for a bad componet. If you do get a picture with the red connected to the green then the red tube is shot. If you know how to read a schematic, get one and then you should have no problem troubleshooting the red drive and the convergence problem. If you dont then there is no easy or quick fix as this is a solid state set and there are no user replaceable parts inside this.,. Your going to need, for safetys sake, call in a trained tech to assist you with this repair
Sep 15, 2006 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
