Question about Dryers
Dryer 3 cycles to dry a load , lint build up around heating elem
Dryer takes three to four cycles to dry a load even if I put only half a load in it. In opening the bottom panel there is lint everywhere. if the seal is broken on the immediate metal plate are these the symptoms?
we took it off and got lint out once with no change.
  • jeremymclero Feb 07, 2010
    Thanks for your answer but I should have given more details. The heating element never shuts off, we have cleaned the vent and it is all clear. I just finished putting new seals on the entire front assembly. Lets hope this load dries okay...
    part of me says that the front half under suction shouldn't be leaking lint outward, but I know hunches are often wrong. I'm wondering about the air intake...
    Scholar:
  • 91 Answers
Try cleaning ur exhaust vent u may have lint in it an this is causing ur dryer to overheat an kill the flame on the burner......this could be the reason u dont have heat because it shuts off as soon as it fires up
Posted on Feb 06, 2010
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Dryer gets low heat takes three cycles to dry a small load, I checked the gas flow and it comes on and burns blue but must not cycle right because the clothes are not drying. I have never repaired a...
If a dryer is heating but takes to long to dry you can bet the dryer has a air flow problem. I would check the dryer vent first for restrictions due to lint build up or kinks. Remove the dryer vent and clean the lint out. Also check the outside flapper on the end of the dryer vent to make sure it's free of lint and able to open all the way.
It also a good idea to take the dryer apart and check around the blower/fan housing for lint build up.
Aug 07, 2011 | Dryers
Our GE Profile DPSB613ED2WW dryer has been losing drying efficiency for the past few months. It now takes three cycles to completely dry a load. The dryer is heating (although we assume not correctly) and...
How is the vent discharge air flow out the back of dryer? If not very strong check out lint trap cavity for blockage or obstuction causing lint to build up, blocking air flow from drum cavity. Once found a pocket comb that had got into lint trap housing and created a lint dam blocking air flow.
Feb 14, 2011 | GE Dryers
We have a WHIRLPOOL dryer model # KGYE670BWH3 and the problem is that when switching from a high to low temperature it stays high at hot rather then low temperature. but then after awhile it will go low.
Hi and welcome to FixYa. I am Kelly.
Lets talk about the physics of changing drying temps mid cycle. The dryer has built up an average temperature that is high when you had high selected. The clothes are hot. The drum is hot and the chassis / ducting is also hot. It can take almost 10 minutes for that residual heat to be removed before you notice that the drying temp has changed.
Having said that, there are a few things to check as to why it is taking an extended period to dry your clothes and why the dryer seems to be running hot.
1. Check the outside dryer vent flapper for lint build up.
2. Check the ducting for lint fromt he dryer exit to the outside vent flapper.
3. Remove the lint filter and look for lint build up around the lint filter ducting. (if it needs cleand do NOT use anything sharp to remove the lint.) A vacuume crevice tool and an old coat hanger folded in half works great.
After checking all of the above and making sure they are ALL clean, try your mid cycle change again an see if it takes less time to notice a difference.
If it is still taking a long time there may be a problem with the temp selector switch.
That is it for now.
Thanks for using FixYa.
Kelly
Mar 05, 2010 | Dryers
Laundry not getting dry
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jul 18, 2009 | Dryers
LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
Vent
Heating element
Internal ductwork
Cycling thermostat
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 29, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
Vent
Heating element
Internal ductwork
Cycling thermostat
May 28, 2009 | Kenmore 64902 Electric Dryer
THE DRYER TAKES TWO TO THREE HOURS TO DRY ONE LOAD
Vent
Heating element
Internal ductwork
Cycling thermostat
May 20, 2009 | Dryers
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Dryers Logo
144 people viewed this question
Top Dryers Experts
