Question about Amana ABB1927DE Bottom Freezer Refrigerator
My refrigerator my amana refrigerator isn't cooling.... the lights work and so does the disputer fan.. it isn't getting no cold air at all...
How do i know if the compressor is running or not
Posted on Feb 24, 2008
  • 958 Answers
Is the compressor running?. check the compressor at the back side of the refrigerator.
Posted on Feb 21, 2008
The refrigerator portion of my Amana ARB2217CW stopped cooling (the fan is still running), but the freezer drawer portion still works fine. What can
most likely you have a bad damper,go here to see it
http://www.repairclinic.com/PartDetail/Damper/67003410/1025326
all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air to the fridge section and it goes through the damper,when it gets cold enough in the fridge section the thermostat on the damper closes the damper door,your damper broke in the closed position,this is as long as the door wasn't left open or anything like that,if it was the air ducts could have froze up but most likely it will be the damper.go here and it will show you where it is up near the light in the back and it's part number 18.hope this helps
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ARB2217CWPARB2217CW1/1268/0161000/M0403273/00003?blt=06&prst=&shdMod=
Sep 04, 2012 | Amana Refrigerators
Motor in the backs works lights works small fan inside the cool side is not working when pluged in problem will not cool
the fan in the freezer is supposed to circulate the air through out the entire box both ref/freezer. If you take back wall off the freezer and their is frost build up, the compressor and all associated parts that make it cold are working fine but that fan isn't blowing the air and the fan needs to be replaced.
Gene
Aug 06, 2011 | Amana Refrigerators
I have a side by side ref/frez Amana ars266zbw the freezer works fine but the refridgerator isn't coolig
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Amana ARS266ZBS Side by Side Refrigerator
The freezer portion works, the fan and light in refrigerator section works but Fridge does not get cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Amana ARB2257CSR Bottom Freezer...
Fan in freezer runs and is cold. No air is coming
heatman101
Sep 17, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge is not cold but the light will turn on...
Hi, Has it been 30 minutes since you turned it back on? It might be in defrost cycle. Please let me know I can assist you further.
Vic
May 30, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
137 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
