Question about Garden
The engine is flooding while trying to start - Garden
  • 2 more comments
  • lindsay836
    lindsay836 May 11, 2010
    Make sure your choke is off, and that you have fresh fuel and correct fuel mixture with a good spark plug.
    What brand saw is it ?
    Please let me know how it goes.
  • dontbother10
    dontbother10 May 11, 2010
    Clean the air filter and spark arrestor (muffler).
  • dontbother10
    Which model and serial? So I can find your start procedure?
  • dontbother10
    OPEN THE CHOKE!!!
    President:
  • 2,220 Answers
Drain and refill the feul tank with mix less then 1.5 months old.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If it still does not start reply (with what you have done and we will continue. HTH
Lou
Posted on Feb 09, 2010
1997 sl2 satun started with rough idol now won't start . cranks over and floods. has new fuel filter & air filter
Check the fuel pressure regulator. Pull the vacuum hose off it, If it smells of gas, Replace the regulator. Diaphragm broke and is flooding the engine threw that vacuum line. You'll also need to replace the spark plugs. Gas will foul them out also.
Dec 31, 2016 | Cars & Trucks
ISUZU I370 RELAY SWITCH
not tuned up?
what engine, ?
flooding , try cranking WOT to clear all flooding.
when wont start, check for spark,????
if diesel, then try posting engine type. exact isuzu name.
or if really savvy? the country first.
Jul 07, 2014 | 2008 Isuzu i-370 Crew
Engine flooding
Check the fuel pressure. The pressure regulator may have gone bad and is delivering too much pressure to the fuel rail, thereby flooding the engine.
Dec 07, 2013 | Cars & Trucks
Fluids out when you try to start
double posted, and fluids? you mean FLOODS.
see previous post,
there are other ways to flood any motor.
one other is (iSC /IAC devices are stuck closed) gummed up.
this cause no starting air, no air means flooding.
I cant see your car, and see if starting with 10% throttle solves the flood, but you can.
also WOT cranking, cuts all fueling and can not flood and will start any flooded engine.
but if this still floods,now, that is bad injectors. leaking.
WOT cuts injection pulses dead, and no fuel flows, cranking.
knowing these facts on EFI makes finding causes easy.
Sep 20, 2013 | 1995 Honda Passport
Trys to flood on cold start
what vechicle type model and the year.older cars carb type if automatic choke not working or vacuum pull off not working carb will flood out engine.for cold start up engine need good spark and fuel.if engine flooding could have weak spark due to worn out spark plugs and wires.could have vacuum leak or bad engine coolant temperature sensor.dirty air filter.dirty fuel injectors.
Dec 20, 2012 | Cars & Trucks
2007 Honda CBF 600 engine flooded
Hi, Anonymous the best way to clear a flooded engine is:
1. Turn fuel valve to off.
2. Remove the spark plugs and clean or replace as needed.
3. Crank the engine over for about 10 seconds.
4. Replace the spark plugs.
5. Turn on fuel valve.
6. Start the bike with minimum or no choke.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Engine flooded Please help
HONDA CBR WONT START TRY THESE TIPS
Honda CBF600SA Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
https://www.acura.com/assets/OWNERLINK/Model/own_man/powersports/2004/2004_CB600F.pdf
May 28, 2012 | 2007 Honda CBF 600
My aprilia 125 moped will not start, there is a spark at the plug, stinks of flooded fuel, it's soaking the plug when kicked over, what's problem?
Sounds like the engine is flooded with gas.Turn the fuel off if you can.Remove the spark plug and move the wire away from the spark plug hole.Now turn the engine over like your trying to start it.See if gas comes out spark plug hole if yes engine is flooded.If it is flood that bad your exhaust will have fuel in it also.You should get a new spark plug before trying to start it again.If gas does not come out the plug hole.Install the new plug and try starting it with the fuel off.Hope this helps.
D.
Sep 30, 2010 | Aprilia RX 125 Motorcycles
98 camaro will crank but wont start after i let it sit for about 15 minutes and try again it will turn over but it doesnt always do this it only does it every now and then.
You could have a leaking fuel injector that is causing it not to start after it sits for a while the engine cylinder may become flooded with fuel and when you go to start it again it will not crank because the engine is hydrolocked. Check the oil to see if it smells like fuel. also remove the spark plugs to see if they are fuel soaked. If you find one. You'll know that's your problem and you will need to change your injectors
Feb 25, 2010 | Chevrolet Camaro Cars & Trucks
Car is getting harder to start
If you think the engine is flooded hold the gas pedal about half way down, while you try to start it. Be ready to release the pedal as soon as it starts. That tells the computer that you think the engine is flooded and it will cut back on the fuel delivery, until the engine starts. You may have a bad fuel pressure regulator. I'm sorry I don't know too much about Subaru's.
Jan 02, 2010 | 1997 Subaru Legacy
The engine on my Sprint 375 floods when trying to start
Check the float in the carb. bowl for gumming and clean your carb.. If you haven't done so already. Or you can try running a fuel treatment through your fuel. That may help you with your flooding issues. Good luck.
May 04, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
221 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
