Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
The freezer is not cold enough but i don't see a temperature control inside. Does the one in the fridge also control the freezer?
    Sergeant:
    Champion:
  • 263 Answers
Correct. The fridge works 100% off the freezer anyways. So they installed the sensor right between the freezer and fridge if you look inside you can see it.
Whirlpool refrigerator repair orange county, ca
Posted on Feb 06, 2010
huuum
  • 750 Answers
SOURCE: Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Posted on Oct 03, 2008
  • 1462 Answers
SOURCE: Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
Posted on Jun 30, 2008
Sea Breeze
  • 4654 Answers
SOURCE: My fridge IS NOT getting cold enough. Temp control is maXxed. The freezer seems cold enough and making ice cubes. this is a GE fridge model #TBF16DRB
Try cleaning the coils beneath the refrigerator. Its possible that they are covered with dust and blocking a fresh flow of cool air to help cool the refrigerator inside. Just a little cleaning there will make a big difference. Check your door seals also a small opening will let the cool out and the hot in. Thanks, Sea Breeze
Posted on Apr 27, 2009
SOURCE: Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Posted on Apr 28, 2009
SOURCE: The temperature controls for the refrigerator are not responding. The freezer controls respond just fine. My fridge is set to 34 and I need to get it back to 37 but it won't change the numbers.
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
Posted on May 14, 2009
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
I have a 2yr. old Maytag Frig.,freezer on top.I cannot get a stable freezing temp. I can set, with the setting control, readings of 4 or 7 with no effect on the actual temp. I bought a freezer thermometer...
If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
How To Check the Temperature1x1.gif In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Refrigerators
Westinghouse RJ532, 530 Litre, Frost Free Fridge/Freezer keeps stopping - if we move the little red dial in the fridge under the air temperature control it starts up again, goes for awhile and then stops....
If the refrigerator was tipped on back or side, even part way, it has to wit upright at least overnight, because of the freon flowing upward.
If you just moved in and it has been sitting and unplugged, then it may be low on freon.
Here are some tips
If you open the fresh food compartment of your fridge (the non-freezer compartment), you will most likely see two different controls. One refers to the refrigerator temperature and the other refers to the freezer. Different manufacturers use different wording, but the idea is the same.
The first thing you need to know in order to understand what these controls really do is that all the cold air in the entire refrigerator is made in the freezer compartment. A portion of that cold air is then blown into the fresh food compartment. How much cold air gets blown in is controlled by the "freezer" control, which is really just an air baffle that opens or closed to let more or less air into the fresh food compartment. The "refrigerator" control is actually a thermostat that feels the temperature inside the fresh food compartment and turns the compressor on and off according to the temperature that the thermostat feels.
Let’s run through an example. Suppose you decide that your ice cream isn’t hard enough. You adjust the "freezer" control to make your freezer colder. What you’re actually doing is restricting the amount of cold air that gets blown from the freezer into the fresh food compartment and so keeping more of the cold air in the freezer. As a result, the freezer will get colder but also the fresh food compartment will tend to get warmer because its cold air supply has been diminished. The "refrigerator" control (the thermostat) will feel this increase in temperature inside the fresh food compartment and will keep the compressor running longer in order to maintain the temperature setting on the "refrigerator" control. So, you can see that any change you make to one control will affect the other.
Many people then wonder, "Well, how do I know what the correct setting on the controls should be?" Since the temperature inside a refrigerator will vary according to lots of external factors such as frequency and duration of door openings, it is impossible to say where your controls should be set all the time in order to maintain a desired temperature in the freezer and fresh food compartments without knowing the actual temperature inside both compartments. For this reason, you should place two thermometers in your refrigerator: one in the fresh food compartment (the big one) and the other in your freezer. The controls should then be adjusted to achieve -10 to +10ºF in the freezer and between 36 and 38ºF in the fresh food compartment.
Keep in mind, too, that it takes 24 hours for any change in the controls to work through the system and reach steady state so don’t look for instantaneous changes in temperature when you make control setting changes. Knowing the actual temperature inside your refrigerator compartments is also a great way to save money on your power bill since you can adjust the controls to avoid running your compressor longer than needed to keep your food cold.
Mar 16, 2008 | Refrigerators
Why doesnt the refrigerator and freezer not get cold enough?
You need to check a few things -
1. settings for the temperature are not set too low. Not cold enough.
2 there is no leakage through the door seals.
3. there is not too much ice formed inside the freezer walls. Needs defrost.
4. the fridge is not overloaded with stuff - not enough capacity to cool things.
5. Not enough free space behind the fridge to allow air movement for coils to cool
Please provide more details of the problem if above not helping. For example model number, is the problem happening both in freezer and refrigerator settings. Get a fridge thermometer and monitor temperature in both sections. should be 4 deg C in fridge and -18 deg C in freezer after stable operation.
Apr 23, 2014 | GE Refrigerators
Fridge is cold, freezer is not
Please look into the freezer for frost build-up on the rear wall. If you are having a defrost problem it may limit the freezer temperature and still be cold enough for the fresh food section to remain at safe temperatures but not for long before freezer and fresh food section warms because frost blocks airflow and the evaporator is unable to keep everything cold because of frost build-up. I don't have your model number so I will list the parts that may need to be replaced. The defrost control=> 12002754 Frost Kit, defrost thermostat and 67002493 Defrost Heater Assembly
67003426 Defrost Thermostat
For testing of the defrost thermosat and defrost heater refer to the same page as the parts, If these parts are good the the 12002754 Frost Kit, could be defective. The 12002754 Frost Kit,
can be found in the control panel inside the fresh food compartment. Let me know if you have questions and also if you are not having a defrost problem, Thanks Sea Breeze
Locate your model number
Aug 22, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Freezer is good. Fridge is not cold enough. It is on 7. MTF2195
Refrigeration half of fridge does not have a cooling unit. It gets its cold from the freezer. There is a door between the fridge and the freezer which is controlled by the fridge temperature control knob. Often times the connection is purely mechanical. There may also be a fan to push the air through the door which is controlled by the fridge temperature knob which is actually a thermostat.
Jun 11, 2011 | Maytag MTF2195 Top Freezer Refrigerator
I have a rm2611 refrigerator which has lights, no fan
There's a capacitor by or on the compressor that probalbly needs replacing. This is the cheapest route .
Jul 05, 2009 | Dometic RM2620 Refrigerator
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
Oct 08, 2008 | Whirlpool Refrigerators
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
399 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
