Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Compressor runs, but not hot to touch
Temperature alarm went off on our 1998 Kenmore model 2539280412. I pulled the panel over the evaporator and found a small amount of ice on the tubes leading to the evaporator coil and ice was plugging the drain hole. The compressor was warm, but not hot, to the touch after a minute or more of run-time. Is it time to replace the fridge? I can't think of anything that would cause the compressor to not run hot. Thanks!
  • 2 more comments
  • Weedoc Feb 21, 2008
    OK, this morning the compressor was hot, sides of the cabinet are NOT hot, and there's a puddle of water on the floor. Temperature inside is above freezing point.
    Replacing the compressor is beyond my ability. I can swap parts like relays and timers, but I'm not qualified to pressurize systems. Is there something besides a refrigerant leak or bad compressor that would fit all these symptoms? Thanks!
    By the way, I melted the ice off the evaporator and cleared the drain tube when I discovered those problems.
  • Weedoc Feb 22, 2008
    Wait a second...the compressor (and condensor) SHOULD be HOT when it's working properly...
    Guru:
  • 1,894 Answers
Hello sir
Posted on Feb 21, 2008
  • dewan nafees ahmed Feb 21, 2008
    here you go...
    i can suggest you to replace your compressor and try working it..
    if the fridge is more than ten years old then i would suggest you to replace the fridge.. that would be the best option..
    thank you
    good luck
    dont forget to rate the solution
  • dewan nafees ahmed Feb 22, 2008
    then the defroster might be becoming aged one....
    this could also a reason for making the compressor warm...
    thank you
Continental Freezer model F2 404A refrigerant not cooling properly. Replaced cap tube, and filter drier, evacuated, and charged. Box temp not going below 32' and ice forming at beginning of evaporator....
Check the compressor efficiency. See if it will pump down. In most cases, a good compressor will pull down to about 15" vacuum. Also, be sure that the refrigerant amount was weighed in and not done by pressures only.
May 18, 2017 | Continental Freezer Wide...
Fridgidaire freezer warming up
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 09, 2013 | Freezers
Temperature alarm light is on and a small amount of water is noted on the floor at the bottom of the freezer. Ice cream is a little soft.
The defrost element has failed, ice buildup will be noted at the inside rear of unit lower. Replace defrost element (service tech required). fixed and many years trouble free, very common.
Sep 01, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
Kenmore freezer depleting 9 volt batteries, setting off alarm
trojo50,
your defrost elements are not working or the water inlet for the evaporator tray is clogged. That alarm is to let you know something else has triggered it. This could be s imple DYI solution or require a service call. let me know if you are up for the DYI.
randy320sgi
Feb 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Runs -6far. for about 2 weeks, then alarm sounds, unit is warm.
its the problem of the motor which runs the fan.that motor needs replacement.a very chance it can be possible that the motor is perfect but the wirings from the motor which connects to the fan are faulty and got cut in between.but it can be possible.so first check out the wirings if they r perfect then its faulty fan  motor.get it replaced. thanks.
Feb 10, 2009 | Kenmore Freezers
FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
238 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
