Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I have a bizhub C550 color copier a error trouble code C-2A04 just popped up what can I do to get it running its the weekend no service tech available!
    Sniper:
  • 62 Answers
Hi Kiddco,
Sorry, this probably a bit late for you. It's Sunday evening here in the UK.
C-2A04 is an internal error of the EEPROM.
The only thing you can really do is turn the main power swich (the big one under the flap) off and leave it for about 10 seconds. Then turn back on and cross your fingers.
I'd generally look over the machine too, just in case there's any paper stuck.
Good luck
Posted on Feb 07, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
How do i solve a p9 and p21 error code
You remove the PRINT HEAD????? DID YOU FOLLOW THE Service manual????????? Well you caused your own problem now you need to do a alignment. of the colors. you also might check the ribbon cable you removed and all the connectors you played with and check each one is secured. Recommend you don't ever remove the print head which houses the LASER unless you follow the service manual. Well you need to get to service mode and run registration procedures. try this site for a service manual or better yey have tech come out and run the required checks.
Service manuals electronic components datasheets and equipment schematics...
Apr 28, 2016 | Konica Minolta Bizhub C550
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Bizhub c550 how to run black imaging unit motor
can not be done does not have that function available in the service mode can only check sensor can not run motors or what is call LOAD CHECK
Apr 30, 2014 | Konica Minolta Bizhub C550
Iam getting p21 c650 and developer
Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Apr 24, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
Bizhub c550 error code c3b04
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
IF THIS CODE COMES BACK GET A TECH YOU HAVE A PROBLEM WITH FUSER WHICH CAN CATCH ON FIRE RUINING A PERFECTLY GOOD DAY.
Feb 01, 2014 | Konica Minolta bizhub C450P Laser Printer
TROUBLE CODE C173
Have a tech come out re-flash th copier os and also check the NVRAM board firmware, mite also be the control board
Jan 16, 2014 | Konica Minolta Bizhub C452 Color Copier...
C-1116 message on Bizhub 500
In Konica minolta Buz C550 copier teh C-1116 error code refer to :
output OP center press transportation motor drive.Check the transmission driver mechanical components(gears,rollers).To reset press and hold on the Utility key and turn ON the copier,wait to displayed Trouble reset message,release the Utility key ,touch the message,turn OFF the copier ,wait 2 minutes and turn ON.
Mar 07, 2013 | Konica Minolta bizhub C250 All-In-One...
C-550 service code CD403
C-D403 code is a checksum error. Clean the connections and reseat the 2 ddr ram boards , If you still have the issue-replace the ram. That will fix it.
Aug 08, 2012 | Konica Minolta Bizhub C550 Color...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
343 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
