Question about Pioneer Car Audio & Video
Why does my Pioneer XM satellite radio say antenna when i turn the power on? First time installing.
    Sergeant:
  • 306 Answers
Sounds like you have a bad antenna or you pinched the wire somewhere
Posted on Feb 06, 2010
Won't power on
Have you tried plutting it in directly to the power source with out the battery? If this works, it may be that the battery is dead, you can try to jump it by putting the battery in after it has already been turned on. Or just replace the battery:
http://www.tss-radio.com/products/replacement-battery-for-pioneer-inno-and-samsung-helix-xm-radios
If it does not power on, it could be the power cord is bad:
http://www.tss-radio.com/products/xm-5v-home-ac-power-adapter
Otherwise, the unit itself may just be dead.
Jun 26, 2012 | Pioneer GEX-INNO1 XM Radio Receiver with...
MANUAL FOR XM SKYBOX
Unit is very straightforward to operate. Hold down O/1 button for power. Use the "mode" pusbutton to cycle thru AM/FM/CD/AUX/XM. Treble & Bass settings are made by turning the 'tuning' knob.
For radio and satellite presets, hold in the numbered pushbutton until it beeps, and then it's set. You should be able to hear previews on XM channel 1,and that will help you with antenna setup. I highly suggest using the remote XM antenna. The built-in XM antenna need to be put 'propped-up' outslde, otherwise you have to use the external antenna. Use AC power as it eats batteries, or use rechargeable D batteries. Let me know if you have any more quesions. okay?
Dec 02, 2010 | XM Radio Audio Players & Recorders
Installation
Go to the XM Radio DOT com website for directions. Basically you just need to mount the antenna on metal, rought the Antenna wire to the Mobile/Vehicle adapter base; plug the cigarrette / power plug in and lug the other end into vehicle adapter base. Go to MENU and pick your blank FM frequency for the radio to tranmit on That's all it takes!
Sep 07, 2010 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
XM radio is not working. Tries to 'Load' but then says 'no signal'. XM says that I am receiving the signal but Honda says there is no problem. They want to try to replace the antenna for $500 but are...
You best bet - if you can get to the rear of the XM tuner unit, is to temporarily connect a magnetic-mount XM antenna and see if it works. A bad antenna usually says "check antenna" - not loading could be a good antenna with a bad location. I would try the little XM antenna by itself, then go from there. $20 is a lot cheaper than $500. Let me know how it works out.
Oct 30, 2009 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
Pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
Apr 02, 2009 | Pioneer XM2go Inno Satellite Radio...
Xm radio installation in house
hi there..this will be like a walk in a park...first, in your home kit you should be having the ff: antenna, rca cable(audio cables), power adapter & docking station. We just have to 'placed the radio into the docking station' then we just have to plug in the ff cables into the xm receiver..we can start plugging in the rca cable(one ended connector) into the ' audio out ' of your xm radio...the other ends of the rca cables should be plug in into the 'audio in'(at the back/infront of your sound system)...plug in the antenna in the 'antenna out' of your xm( the antenna should be placed into a south facing window and not being block by tall trees and buildings outside)....plug in the power source and turn on the radio....if you got it right you should now be getting the prev.channels/emergency allerts...u can call xm to send a refresh for you to get the complete channels..or you can do it online by logging into www.refresh.xmradio.com(if the radio was already activated) if not, you have to call xm radio to activate it..enjoy listening to xm..Godbless..
Sep 05, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Apr 08, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
No XM Audio, no fault indication
Buss cable is plugged into the wrong connector on the GEX-P920XM. The installation manual is not clearly written, the figure in the manual is correct.
Sep 22, 2006 | Pioneer GEX-P920XM Satellite Radio...
Car Audio & Video Logo
65 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
