Question about GE DBXR453EV Dryer
Need wiring diagram for ge timer
Need wiring diagram for ge dryer timer
hiltonjug
  • 612 Answers
SOURCE: need color code wire diagram for control wires on
This info should be located behind the control panel of your dryer. If not, someone must have removed, try asking again if it's gone.
Posted on Oct 19, 2009
TheMobilian
  • 8220 Answers
SOURCE: TIMER WIRE DIAGRAM
Just attach the green wire to any screw closeby. Nothing could be simpler. Look closely and you will find a small male terminal to connect the green wire in some models.
Posted on May 13, 2009
  • 1214 Answers
SOURCE: need wiring diagram for light in ge dryer
Most all washers and dryers have a wiring diagram inside of the service panel on the rear of the appliance.
If you know you have a good bulb, then the problem is very likely the door switch. The circuit for the bulb is pretty straight forward, so if it's not the bulb, it's the switch.
Posted on Dec 10, 2009
wfservices
  • 262 Answers
SOURCE: looking for dryer diagram
There should be a schematic on the inside of the back cover, sometimes it is located in the top control panel somewhere(timer panel)
Posted on Feb 23, 2010
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 | GE Dryers
Timer does not seem to be working on auto
If have a wiring/scematic diagram for the machine and a meter, you might try tracing the problem that way, just a thought may be a loose or bad wire on the back of the timer. It could be possible that the timer may have gone bad. Please let me know if this helps you in anyway.
Mar 21, 2014 | GE DRSR483ED Electric Dryer
I need a wiring diagram for a ge 240 vac timer please
GE sells several timers rated for 240Volts.
Including the 15307 timer made by Tork, rated 208-277Volts, 40 amp, 60 Hz
Copy following link for wiring GE 240Volt timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Oct 18, 2012 | GE 15307 240 VAC 24-Hour Outdoor...
I don't know where the color cables go on the timer pals shaft for my ge dryer
you need to find wiring diagram it should be in the console with the timer the wiring diagram will tell you which wires go where
Aug 26, 2012 | GE TIMER PLAS. SHAFT - WE4M366
Need color coded wiring diagram to install timer switch on ge dryer model#dbxr463eg2ww asap!
what happened to the wiring diagram that was located inside of the control panel
Jul 23, 2011 | General Electric DBXR463EG Dryer
I need help to install pool pump to mechanical intermatic timer switch GE to replace the digital control.
Question is not clear.
Add a comment with missing information for exact wiring diagrams.
Voltage is not known.
Timer model numbers are not known.
You have two timers.
You are replacing unknown electronic timer with unknown mechanical timer.
Intermatic timers and GE timers are different companies, and each makes many different timers
Each box timer has identification on inside of timer door.
Open following links to help identify timer and see wiring diagrams.
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jul 14, 2011 | Intermatic T104 24h 208-277v Mechanical...
Changed high temp thermostats, maybe hooked wires back up wrong?
you should have a wiring schematic diagram somewhere on the machine otherwise the limit switches are normally wired in series w/element
Aug 15, 2009 | GE DVLR223 Dryers
TIMER WIRE DIAGRAM
Feb 19, 2009 | GE DBL333EA Electric Dryer
Ge Commercial Coin-Op Dryer.
When you replaced the motor, did you replace the relay? It sounds like you have done everything reasonable. I would try bypassing the coin operation part and see if that changes anything. Go back to the motor relay. It may be incorrect application. the part guys only know what the computer tells them. it may need a different one. I am assuming that when the unit shuts off you checked for power from the timer to the next place, according to the diagram.
Mar 13, 2008 | Dryers
Dryers Logo
291 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
