Question about Jl Audio 13W7 Car Subwoofer
Why doesnt my jl 1000.1 pick up my 13.5w7
I connected the sub to the amp and it doesnt it hard at all!!! what can be the problem?
  • 24 Answers
Ohm load check the way you wired it if the amp can handle 1ohm make the sub 1 ohm dule 2 ohm subs hook the neg from one coil to the pos on the other then take the empty neg hook it bridged to the neg on the amp and empty pos to the pos on the amp also check to see if you hooked it up bacwards subs dont hit hard when they are beating in and not out
Posted on Feb 06, 2010
3 Suggested Answers
pjstanley
  • 185 Answers
SOURCE: If I buy 2 12
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Posted on Oct 31, 2008
rteemon
  • 578 Answers
SOURCE: JL Audio 13w7 & 1000/1 Amp Settings
that depend on how you wire the speaker my friend and the performance of you am and u have to use jl -dclass series amp for the best performance of those speakers
Posted on Aug 07, 2009
Can i run a 4ohm.dvc & a 3ohm.svc off of a mtx te 801d
if you wire the 4 ohm sub voice coils in parallel you will have a 2 ohm load for the Image Dynamics sub, the JL sub only being single voice coil will of course be 3 ohm.
You cannot connect them both to the amp you specified as when connected the total load will be less than 2ohms and the amp will either trip it's protection circuit or could damage the amp, My suggestion is to try each sub separately and decide on the one you like the most or obtain a matching pair for the 4ohm DVC.
Mar 05, 2012 | Car Audio & Video
Jl 1000.1 Bottoming out my sub at very low volume...i have a 1000d cross fire mono block that POUNDS my sub and doesnt bottom it out.. but when i hook up the JL i get to quarter volume and the sub starts...
Check The Settings On The Amp.... There Is Probably a Setting Turned All The Way To Max on it. Is There 2 Rca Cables Hooked to It ? Try Switching them around And Seeing if It Gets Better Or Un Plug one of them And See if It Gets Any Better, Would Definitely Check The Settings On The Amp First to See if That your Problem. Hope This Helps :-)
Mar 10, 2011 | Jl Audio 1000/1 Car Audio Amplifier
No sound
ok if u have a radio with sub controll make sure its on an make sure that you have the gain bassboost turned up an if it has a crossover switch make that its on
Jul 24, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 1000/1 feedback tone
your aux cords could be craked or cut somwhere
Jun 07, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
Shuts off when the volume gets turned up didnt do this wen new
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
Apr 06, 2010 | Kenwood KDC-BT838U Car CD Player
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
No sound out of subs
undo all the wires to the amp and the speakers and simply rewire em.
Feb 25, 2009 | Jl Audio 12W3 Car Subwoofer
Jl audio amp 1000/1 fix
IVE HAD 2 JL 1000/1S DO THIS TO ME EACH TIME ITS TURNED OUT TO BE A SHORT IN THE RCA IMPUT BUT ALSO CHECK YOUR RCA CABLES AND THE SUB INPUT ON YOUR HEADUNIT
Dec 22, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 13W7 Car Subwoofer Logo
236 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
